Jeez! Do pinball machines ever STAY working right?
Thought I had everything working 100% and now I've lost some sounds. In test mode all music and sounds test good. I recently got my CPU back from being repaired for another issue and was assured the board was 100%. Was upgraded with new roms as well.
After I installed my CPU and played some games, some times the speech would work and other times it would be gone altogether. It seems to have gotten gradually worse now I have little or no speech at all. It's kind of random. Another thing happening during play is the background music will occasionally fade to a lower volume for 2 or 3 seconds. I can't associate this with any particular event.
I have read everything I can about sys 11 issues and found the speech sounds are coming from the CPU. I swapped the ribbon cable with my F14 and that made no difference. Replaced all of the radial caps on the sound board. From what I've read, it looks like U4 and U5 1458 op amps and U3 55536 could be suspect. Is there a way to test these in a random situation? Is there anything else I should be looking at?
I have a logic tester but don't really know how to use it.
Any help is greatly appreciated.
