(Topic ID: 334426)
Pinbot System 11 GI Only..
By mcvetyty
6 months ago
  • 11 posts
  • 3 Pinsiders participating
  • Latest reply 5 months ago by Billc479
#1 6 months ago
Hello -
Hoping someone can give me a starting place to dig into an issue I am having with my Pinbot machine. It was working fine this morning, but now I turn it on and ONLY get the GI. No boot tone, no solonoids firing, no displays, nothing else.. I checked the fuses and all seems good, but based on the amount of things not powering, I assume this is larger than a fuse issue.. Any direction on where I should start troubleshooting would be much appreciated!
#3 5 months ago
How is it coming along? Any updates?
#4 5 months ago
Quoted from Billc479:
Hey Billc479 - Sorry for the lack of updates, was waiting on a shipment of fuses which just arrived.. So, unfortunately, still having an issue but here's where we are at...
-Thank you for the article! Reading through that helped me to understand the 'flow' of how the machine boots..
-In following that flow, I discovered the MPU board is not getting any power.
-This helped me find that one of the two logic fuses (F5) was blown on the power supply board.
-I ordered new fuses which arrived today - and unfortunately the fuse continues to blow immediately upon powering on, so clearly something is wrong resulting in blowing the fuse..
So, now what? How do I narrow down whats going on? Appreciate your help!
#5 5 months ago
I am going to guess you have a bad bridge rectifier on the power supply board, or a shorted capacitor. Look closely at the power board - a bad capacitor sometimes swells and/or leaks its guts out. A bad bridge will sometimes blow a hole thru the block.
#6 5 months ago
Thanks Bill - I will take a look. Is there a way to narrow down which capacitors interact with that fuse? Or do they all?
#8 5 months ago
Do you have the schematics? If not, find a copy - the one on IPDB is a terrible copy of a copy of a bad copy.
Regardless, F5 goes to BR1 and to C7 - a 100uf 25V capacitor. Lift a lead on C7 and see if it is shorted. If its original to the board, then its time to replace it due to age.
Read up on how to test a bridge - I think there's a section in Pinwiki. Sorry I'm not as helpful as others.
#9 5 months ago
Progress?
#10 5 months ago
Hey Billc479 - Thanks for the follow-up. I couldn't see any capacitor issues on the power supply that would lead me to determining where the issue was, so I ended up just replacing it with a new Rottendog one this morning. I am happy to report that this has resolved the problems and PinBot is working once again!! Thank you all for your help !
#11 5 months ago
Are you going to get the old board repaired as a spare?
$ 52.99
Pinball Shark
Shooter rods
This page was printed from https://pinside.com/pinball/forum/topic/pinbot-system-11-gi-only and we tried optimising it for printing. Some page elements may have been deliberately hidden.
