I haven't had a problem with the wiring on this thing the little over a week I've had it. I turned it on a moment ago and it is kicking up a complaint about switch 40 and 45 which I know is related to the ramp.
I popped the top, saw the brown wire was almost detached. I heated up the solder and got the old off and put some new. It seemed to be fine for one powering on and play. But when I turned it off and tried it again it started to whine once more about the 2 switches.
I know this is fairly general but what can I do about this? I'm pretty out of it on doing much technical, I have my limits as I can't read schematics, but is there something I can do or am I going to have to place a call on this?
EDIT: It's working again, for this moment. This seems to be intermittent which of course if it is will be maddening. It appears I get the glass off, pull it up, do nothing but look at it, then place it back down, and it's fine. I flip the switch, still fine, clear out the old audits of errors, reset again, still fine. What could make it just randomly get pissy?
