New! Dark mode!
(Topic ID: 228877)
pinbot Startup Issue
By zapfranka
1 year ago
  • 27 posts
  • 8 Pinsiders participating
  • Latest reply 1 year ago by zapfranka
#1 1 year ago
Hello. I am new to Pinside. I have a 1986 Williams Pinbot pinball machine that was working perfectly. Walked into the room the other day and everything was out except for a few lights on the table and backboard. I traced those lights to a connection off the power board. I checked, replaced and rechecked all the fuses and they were fine. I did not see or smell any electrical burn. Unless I'm missing a fuse somewhere I am at a loss what happened. Any advice would be greatly appreciated, as I live in an area where there are no pinball repair people. Thanks in advance.
#2 1 year ago
Quoted from zapfranka:
When checking those fuses did you do so with a dmm in continuity mode? Sadly sometimes a visual inspection is not enough.
Also remove the back glass and turn the game on. Three leds in the mpu should do something. I think the 5v one should be lit at a minimum indicating the mpu is getting the 5v it needs.
#3 1 year ago
thanks for replying. All 11 fuses were replaced with new ones. Plus the main fuse under the table. It completely shut down except for the aux plug under the table and one plug off the power supply board that services some lights. If I unplug that connection then the whole game is dead except the aux plug. MPU is completely shut down as is the sound board. Just plain weird, everything was working great up until that point. Can the power supply board just go out like that?
#4 1 year ago
one time on my pinbot a wire got loose on the molex plug right before the transformer in the bottom of the cab and it was a pain in the ass for me to figure out the issue. I re-seated those wires in the plug and have been good to go every since. Might me something silly like that?
do you have a multimeter to see if you are getting voltage anywhere after the service outlet?
#5 1 year ago
the only power I am getting after the service plug lights up the coin slots and some table lights and backboard lights. That connection is on the far bottom right on the power supply board. unplug that and power stops at the service plug. where is the molex plug located?
#6 1 year ago
So even if they were replaced the next time you flipped the power on to the game they could have blown. On the power supply board check each of those fuses for continuity with the game off. Tell us if any are blown. I suspect F1 or F2 is blown as the mpu isn't booting. GI and the service outlet run though different fuses so they will still work. If all the fuses end up being good then we will need to check the voltages coming off that board as something about it is preventing the game from booting.
My guess is something on that power supply board has died but who knows.
#7 1 year ago
On the transformer should be a clear white block
#8 1 year ago
Found it. Everything seems nice and tight. I moved around wires but still nothing. I'm leaning towards a power board problem, as it was working when I left the room (I told the ghosts to stay away from it) and when I returned it was out. I will check continuity and get back with a result. Thanks again for anyones help. I have had the game for many years and this is the first problem I have had. This is one of the great ones and I really would like to see it working again.
#9 1 year ago
Please provide pictures of the power supply board and its connectors, along with pictures of the SDB and MPU. Different eyes may/will catch different things to check.
#10 1 year ago
Do you have a dmm? If so, see if there is 5v coming out of the power supply. It'll be connector 3j6 on the ps. Black meter wire on ground (black wires on that connector) red meter wire to the grey wires. If no 5v, you have no logic power, and the main computer won't boot. Most of them I get through are bad caps. Common issue on the old power supplies. Good luck!
#11 1 year ago
We'll get ya back up and running good info so far!
#12 1 year ago
thanks guys. I'll get back when I have the pictures and testing done.
#13 1 year ago
Getting closer. continuity test shows no power going thru fuses F5 and F6. the logic supply. The other 9 fuses check fine for continuity. Blown Cap(s)? Will upload some pic's this afternoon.
#14 1 year ago
If you have the means and knowledge, i would put a cap kit in it. They should be replaced after 30 years anyhow. It's likely a bad cap, which is not uncommon.
#15 1 year ago
I am not comfortable doing the caps myself. I can remove the power supply board and reinstall it, but thats where it ends. I will pay anyone who is knowledgeable enough to do it for me. Still want to be 100% sure its a cap problem, but it sure points to that. I'm sure they are original.
#16 1 year ago
I'd say replace that board if the cost isn't too bad for ya. $89? If memory serves I've bought two and having stable power is a huge help when doing diagnostics. Especially if the fuses keep blowing each time you replace those two fuses. I can't remember if either of the bridge rectifiers connect to those fuses but I doubt it.
#17 1 year ago
replaced fuses F5 and F6 now have continuity but still n change
#18 1 year ago
When you powered it back on did any of the leds on the power board come on? If not your not getting the 5v to your mpu. I'd turn on the power once, see if any change and then check all the fuses for continuity as different ones may have blown. If all are still good then we need to start taking readings at the test points on the power supply board and see what values are being returned.
#19 1 year ago
no nothing, but at least the fuses didn't blow. looking at a new used power supply board. 520-5047-00 will that work in my pinbot?
#20 1 year ago
Yes that will work fine.
#21 1 year ago
As will this of you decide to go new
http://rottendog.us/DPS004.html
#22 1 year ago
Love these threads on pinside!...just sayin!
#23 1 year ago
First image is my old board with pin missing. Second is my new board with all pins. 3rd image is my connector. All other plugs work fine except for this CN5. Idea's anyone?
20181123_153154 (resized).jpg20181124_134455 (resized).jpg20181124_134427 (resized).jpg
#24 1 year ago
Could you post a whole pic of each board, old one and new one? Based on the CN nomenclature for the connectors of the new board, i think you may have a Data East power supply board there. (Though I may be wrong about that, perhaps it's an aftermarket board?) If it is a data east board, I don't think they can be used with your game, but i don't know enough to be 100% sure about that.
Either way i wouldn't recommend turning the game on until you are certain the board is compatible with your game and figure out the wiring issue. Something definitely doesn't seem to be adding up...
#25 1 year ago
Quoted from frunch:
It looks like a DE Board to me as well but I have know idea if they are interchangeable.
#26 1 year ago
It you want you can sent me your original power supply and I can rebuild it for you. I would not use that data east power supply.
#27 1 year ago
Hi Grumpy How much for a rebuild? I have the cap set for the power supply board. Also where are you located? thanks
$ 54.99
$ 175.00
Professor Pinball
$ 44.95
PinBoss Mods
$ 54.99
$ 50.00
$ 18.99
Sale Pending!
Bethlehem, PA
3,500 (OBO)
Tulsa, OK
