I am looking for some help with my Pinbot. It has a problem which manifests as frequent triggering of at least one outlane and occasionally as a tilt during play or with a gentle to moderate tap on the lower half of the playfield.
I have noticed also that thumping the playfield is less effective at triggering the problem the more the field is tilted upwards towards fully vertical.
I have checked switch gaps, the diodes on the switches, looked at the wires for obvious shorts and even tiled the playfield up during play to jiggle all of the wires and tap stuff underneath with a wooden dowel trying to trigger it without success.
Does anyone out there have any thoughts/suggestions on how to go about tracing the cause of this issue?
