Hey everyone,
I've had my pins folded up for ~2 years while we were finishing out basement.
Figured I would start with Pin*bot trying to get it up and running first as I knew there were a few issues. I tracked down and fixed most things but I am stuck on these two:
1) The right sling shot switches do not work. The scoring switch does work and the coil fires in test mode. These switches are not part of the switch matrix so I am a bit lost on what to look for.
2) I have all the sound effects but I do not have any music. I previously replaced all the eproms with new ones. I swapped out the sound board with one I had when I had another System 11 in the house and the sound board works fine. I have read that some of the sound is generated on the MPU as well as the soundboard in pinbot so I probably have an issue somewhere on the MPU.
For what its worth, For several years neither of these were an issue and the game operated 100%
Any help would be appreciated
Dave
