Came to play my PIN BOT today but found a ball stuck in the right eye that wouldn't eject. The solenoid test failed, so I started looking around, didn't find any loose wires and the DMM indicated that the coil should be working.
I took the coil and assembly apart, replaced the coil sleeve and cleaned the kicker as it was kind of binding and felt harder to move than the left eye. Didn't fix the problem. Everything else seems to work, although the test is reporting a couple of switch errors (40 and 54 I believe).
Any ideas?
