pinbot- cpu shot, bad corrosion. probably needs displays too. booted up with a ram error, but display was missing segments, so assume they are no good. no backglass. playfield is actually nice, but mylar is lifting on inserts and needs removal. cabinet is pretty good to good. was drilled for a lock bar. no idea if visor works, or anything else is working. supposedly it worked until ignored, then the batteries puked bad. located on long island. was stored in a two car garage in a house, but it was humid, surface rust on the legs. make an offer
thanks
