Hello - Pinbot blew the solenoid power fuse between between the transformer and bridge rectifier (my thanks to the person who added the fuses!!). Blew a second one immediately, so I figured a bad bridge. To make a long story short, I found that one of the ac legs is tied to ground, for both the 26 and 13.5 volt supplies. That’s with everything disconnected to rule out the rectifiers, etc; it’s coming out of 6P1 that way. According to schematic that’s not right. Just wondering if this is correct, a common mod for some reason, or maybe my transformer’s gone bad, and if I need to chase this as an issue.
