Quick update. Yesterday was largely taken up with construction, and I only had a little bit of time before the crew showed up today.
Just about done on the bottom end with the exception of soldering the coils back and the target bank and flippers. Target bank probably won't go back in until the playfield is installed. Little backwards, but it makes it a lot lighter to move.
Tonight if I have time I will rebuild the flippers.
I pretty much finished up the upper part of the bottom of the playfield. I started it, realized nothing lined up in the CPR playfield so I had to take paper and trace the holes in the old playfield. So two steps backwards, but at least now it's all lined up. I just need to run in the rest of the screws. In a strange act of intelligence, I only secured most of the components with one screw until I knew how they would line up so I could shuffle them as needed.
And yes, I could have done better with stencil material, but you work with what you've got
