For the life of my I can't figure out why these two flashers wont work. I have tried everything I can think of to get them to flash without any luck. I have traced the wire up to the main board and it tests fine with continuity test on the multimeter. Then it goes into Q30 Which I have replaced if you ground out Q30 the lights go on so that basically tells me the bulbs and sockets are fine as well. then it goes to Q26 which I replaced as well and then to resistor pack SR7 which I pulled and it tested fine. I also traced the other end to the Diode board under the playfield pulled the diode and it tested fine but swapped it for another anyways. After all that I re-flowed all the headers and the two strobes still wont light. This is the last thing I need to figure out and I have the game working 100% so any help would be appreciated.
