Working on a Pinbot and all of the solenoids stopped working. Fuse is fine, fuse holder is fine, reflowed every connector on the power driver and Power Supply. No luck! The only thing I think it may be is a failing bridge rectifier? It worked for a second then quit shortly after. Any ideas? Could it be that bridge? How can I properly test? Thanks!
