Quoted from ScottSchowiak:I see at 3J8 plug with 8 wires from it and 4 of them are fused but i don't see a fuse before the relay
on page 58 it shows the power supply with six fuses and on my power supply there is seven fuses the one im looking for is just below the relay and on page 58 it just shows a line with no value
There is no fuse before the relay. Typically, the GI on Pinbot has four fuses, branched after the power supply. All four of them would have to be blown to have absolutely no GI....assuming you have the D-8345 power supply, there is usually a large gauge jumper wire below the relay on the bottom right instead of a fuse. A standard 5A fuse would probably blow there...it should at least be a time delay (slow blow) fuse - and probably a bit more than 5A, since EACH branch is fused for 5A and current is additive (Kirchoffs Law) - then there could be potentially as much 20 amps going through that single main fuse!
That said, If it were me, I would make sure the 4 GI branch fuses are 5A S.B., replace the "main" GI fuse holder under the relay by removing the fuse clips and replacing it with a short length of 18g wire.
