(Topic ID: 53470)
Pinbot Freezing during multiball
By charliex
10 years ago
#1 10 years ago
Hi Guys, I know this one has been addressed before.
Here is the scenario:
Each time multiball starts, it runs for about 10-30 seconds, then just freezes and keeps playing the multiball music. The freeze is NOT tied to hitting the flippers. I did change the diodes on both flippers just in case. It just freezes. Most recently, it reset the whole machine in the middle of multiball.
I have an Xpin power supply that I added about a year ago as a reference.
( http://bayareaamusements.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=XP-WMS8345) . So I assume the power is solid.
This never happens outside of multiball.
Thanks.. Joe
#2 10 years ago
Freezing as in it won't register any new score, flippers stop working? Or does the music just stick?
#3 10 years ago
Flippers work. But the mpu won't register score. And no sound effects except the music.
#4 10 years ago
What voltage are you getting on the CPU board?
Did you do ANY servicing before this started?
Did it ever work correctly?
#5 10 years ago
Vid, I won't be able to test the voltage until tomorrow. It used to work perfectly. the last repair I made was replacing a 7402 that was causing a stuck-on jet bumper. Prior to that repair there was no freezing. But I'm not so sure that it started freezing right after that repair. It is possible.
#6 10 years ago
Quoted from charliex:
The 7402 can't be a factor.
I usually don't "go there", but this sounds more like ROM corruption, or access to the ROM has been corrupted/severed.
Reseat the game ROMs and retry.
If you have a burner, verify the checksum of the ROMs, or reburn new ones.
The rationale is that you've stated that this consistently happens during multiball, and only during multiball. i.e. under specific conditions where a different execution path is being followed.
Chris Hibler - CARGPB #31
http://www.Team-EM.com
#7 10 years ago
I will try reseating the ROMs. Additionally, I have the old original ROMs and I can try those as a sanity check. If the old ones work I can get new ones burned as you said.
I'll go that route. It might take me until the weekend to report back due to travel.
JR
#8 10 years ago
if that doesn't work, use a space heater. Least it won't freeze anymore.
#9 10 years ago
Here's the update. I removed and reseated the game and sound ROMs. I tested for about 1/2 hour today and have not seen any freezing yet. I'll keep testing. Keeping my fingers crossed.
#10 10 years ago
Quoted from ChrisHibler:
Just a question... What is the importance of verifying the checksum, what IS the checksum, and what does it mean to burn a rom??
#11 10 years ago
Quoted from ShootForSlrValue:
Think of a rom are a big blank blackboard. The data in the rom is the stuff you write on the board. Now so you know that no one screwed white what you wrote on the board, you take every bit of information add it all up, apply some secret math and come up with a 'checksum' that if needed you can go back and verify in a few days that what you wrote adds up to what is there still.
So basically all your data is added up and a 'special' number is created and written at the end. Now when you boot the easiest way to see if what's in the roms is pure and correct, you read that last special number, then redo all the math to the data and compared to the special number. You check the sum.
#12 10 years ago
And burning the ROM just means writing the data to it. Like saving a file to a flashdrive. First you erase it with a UV light, then you save the new ROM file to the chip using a device called a "rom burner". They have USB devices that you drop the chip in and use a computer to write the file from your computer to the chip.
#13 10 years ago
What Pat and Charlie said...
#14 10 years ago
That's good...and bad...
It may work forever...or you may have an issue with one or more of the sockets.
Under these conditions, if it happens again, I'd replace the game ROM sockets.
#15 10 years ago
Roger that. I agree.. I'll need to have a pinbot fest first this week and make sure its really fixed for the moment. And dude.. You have a huge collection 60 games OMG I'm jealous.
#16 10 years ago
Final update. Its fixed. Reseating was the cure. Thanks again.
#17 10 years ago
As a FINAL FINAL update. Reseating it did not fix it, but replacing the ROMS did fix it.
#18 10 years ago
Thanks for posting the "final final"...
2,800
West Chester, PA
$ 35.99
$ 18.00
$ 39.99
Lighting - Backbox
Twisted Tokens
$ 175.00
Professor Pinball
$ 65.00
$ 2.50
$ 36.95
3,152 (OBO)
Pulaski, PA
4,800 (Firm)
Kingston, OK
$ 69.00
Pinball Pimp
$ 18.95
3,000 (OBO)
Fargo, ND
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/pinbot-freezing-during-multiball and we tried optimising it for printing. Some page elements may have been deliberately hidden.
