Flipper power supply fuse started popping on me today. Everything seems good until either flipper hits the eos switch then the fuse blows. Out of fuses and time at the moment but any advice as to where to go from here would be welcomed. Thx
check your flipper diodes , they will cause this. You need to remove one end to test though. Better to replace them as they are cheap and are a common failure point. And half removed to test anyways.
Also check the coils. if they meter bad,clip one end of the diode and test again if they now test fine the diode was bad.
Also get a 3 amp circuit breaker and attack test clips or solder a blown fuse to the ends and use that so you do not burn through fuses.
This page was printed from https://pinside.com/pinball/forum/topic/pinbot-flippers-died- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
