(Topic ID: 70838)
Pinbot Fans and Owners Club!
By wayout440
10 years ago
  • 6,058 posts
  • 464 Pinsiders participating
  • Latest reply 21 days ago by Neight
  • Topic is favorited by 232 Pinsiders
There are 6,058 posts in this topic. You are on page 83 of 122.
#4101 4 years ago
So I fixed my board and booted the game. Everything seems to work except the slingshots and the pop bumpers. In switch test, none of the switches will register. In play, when I hit the top and bottom pop, it triggers the left and right sling??
The top sling coil is like 5000 degrees like it is locked on, but it isn’t. I can’t figure out what is going on. :/
#4102 4 years ago
Ok, did a lot more diagnostic work today. Unfortunately didn’t solve anything, but I can be more clear on the problem.
The failure is across the two switches which trigger the slings and all three switches which trigger the pops. There is no shared line, and in fact most of these colors are not in the switch matrix. Colors are like solid white, orange-black and black-orange. Is it possible I did something to one of the ICs on the board that is messing this up?
I am confused how these switches are not in the switch matrix. Are they a different style of switch?
2B698C35-5ECC-40F4-AB41-7DA7269FEDEC (resized).jpeg2B698C35-5ECC-40F4-AB41-7DA7269FEDEC (resized).jpeg43D5CF44-D00B-4329-B1E7-9C9CFFA29C30 (resized).jpeg43D5CF44-D00B-4329-B1E7-9C9CFFA29C30 (resized).jpeg581B9C45-DB66-491D-BEE8-FE3DE71133B9 (resized).jpeg581B9C45-DB66-491D-BEE8-FE3DE71133B9 (resized).jpegD0A9CC25-0979-49E9-9641-C43B41DA8AA1 (resized).jpegD0A9CC25-0979-49E9-9641-C43B41DA8AA1 (resized).jpeg
#4103 4 years ago
Quoted from Aniraf:
The white wire is ground. Orange/black is the special solenoid switch wire.
Quoted from Aniraf:
Special solenoids have switches directly connected to the transistor and by pass the switch matrix.
You will need to disconnect J-18 and J-19 and then test the pins of J-18 with a volt meter.
#4104 4 years ago
Quoted from GRUMPY:
Ok, everything is 2.1VDC except pin 5 and 6 starting at the top.
#4105 4 years ago
#4106 4 years ago
Quoted from GRUMPY:
Sorry, yeah I found it. I can’t read the voltage on that diagram.
#4107 4 years ago
Oh, and to correct. My 0 VDC are on 6 and 7. I didn’t count the key pin.
#4108 4 years ago
Quoted from Aniraf:
They should be 5 volts, then when you press the corresponding switch it will drop the zero volts.
#4109 4 years ago
Quoted from GRUMPY:
So what might be limiting the power? I tested all of them for continuity and they seemed to work fine. Should I test the voltage at the switches?
#4110 4 years ago
Quoted from Aniraf:
There will not be any voltage at the switches with the connector removed.
Quoted from Aniraf:
A bad U-45, U-50 or U49 chip. Are any of these chips socketed?
#4111 4 years ago
Quoted from GRUMPY:
None of those chips are socketed. I could shotgun them if you think it is worth replacing them. I just need to order the right stuff.
#4112 4 years ago
If I was to take a guess I would replace U-49 because it connects to all six special solenoids.
#4113 4 years ago
You could cut pin 6 of U-49 and then retest J-18 pin 5 to see if it has gone from 2.1 volts to 5 volts.
#4114 4 years ago
Quoted from GRUMPY:
Do you know happen to know the part number? I can’t see it in any of my pictures and I left the bar :/. Also, if it makes sense I have a logic probe and I could do a test on the IC.
#4115 4 years ago
The part is a hex buffer,
https://www.jameco.com/z/7407-Major-Brands-IC-7407-HEX-BUFFER-DRIVER_49120.html?CID=MERCH
Quoted from Aniraf:
The problem is the output of U-49 is connected to the inputs of U-45 and U-50 and the connector J-18. You can't test one chip with out separating it from the other chip.
#4116 4 years ago
Quoted from GRUMPY:
Is there a way to cut it without destroying it? I don’t know what it is so I can’t look up the data sheet right now. I don’t really care about destroying it if you think that is the way to go, just thinking if something else is the problem I am delaying my fix as I’ll need to order more parts.
#4117 4 years ago
Quoted from Aniraf:
Yes. Use some anvil cutters to cut the chip lead, it can be repaired with a dot of solder.
https://www.amazon.com/Xuron-170-II-Micro-Shear-Flush-Cutter/dp/B000IBSFAI
#4118 4 years ago
Quoted from GRUMPY:
amazon.com link »
While I'm at this...are there any other ICs I should order just so I'm prepared to replace whatever I might need when it comes to fixing this issue? I wish I had a shop in town where I could buy this stuff :/.
#4119 4 years ago
I usually have some AND chips 7408, NOR chips 7402, some predrivers 2n4401, some drivers TIP 102 and some zener diodes 1n4735a and lastly some 1n4007 diodes.
#4120 4 years ago
I put up a post looking for help to trouble shoot my flashers issue.
https://pinside.com/pinball/forum/topic/pinbot-flasher-problems
#4121 4 years ago
Quoted from metalkatt:
Sounds like the AC relay isn't working very good. Dirty contacts. Could also be cracked pins on the relay.
#4122 4 years ago
Quoted from GRUMPY:
The AC relay on the MPU?
#4123 4 years ago
Nope under the play field.
#4124 4 years ago
Quoted from GRUMPY:
Got it. I’ll check it out. Fingers crossed. Thank you
#4125 4 years ago
Something like this will cause problems.
#4126 4 years ago
Quoted from GRUMPY:
OK, so for my stock I am looking at the following:
- 7407 | https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&pa=49120&productId=49120
- 7408 | https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&productId=49146
- 7402 | https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&productId=49015
- 2n4401 | https://www.jameco.com/z/2N4401T-R-Major-Brands-Transistor-2N4401-NPN-General-Purpose_38421.html
- TIP 102 | https://www.jameco.com/z/TIP102-Major-Brands-Transistor-TIP102-Darlington-NPN-100-Volt-8-Amp-TO-220_32977.html
- 1n4735a | https://www.jameco.com/z/1N4735A-Major-Brands-Zener-Diode-1N4735A-Single-6-2-Volt-5-1-watt_36126.html
- 1n4007 | https://www.jameco.com/z/1N4007-Major-Brands-Diode-1N4007-1000-Volt-1-Amp-Silicon-Rectifier_36011.html
I have the TIP102s from the prior fix. I am pretty sure I have some 1n4007s, but I'll double check. The ICs I am certain I don't have. Before I order some of these I figured I would double check the links with you to make sure I'm getting the same stuff. It would be handy to have a few around when I encounter common problems.
#4127 4 years ago
I guess I have 1N4004s. Looks like the 1N4007 is just a better version of that same 1000 volt 1 amp diode?
#4128 4 years ago
Looks good to me.
#4129 4 years ago
Quoted from GRUMPY:
Something like this will cause problems.[quoted image]
So, upon further investigation, none of my C side functions are working. The AC units are clicking fine, but no functions.
#4130 4 years ago
I need a pic of both sides.
#4131 4 years ago
Look carefully at the relay. One time I had a relay on my Taxi where one side basically got too hot and fused itself together. See pic.
#4132 4 years ago
Quoted from GRUMPY:
They all look good to me.
There is that brown section on the one relay... not sure if it is a hot spot?
0859DC46-33F8-4CBF-9548-54233DEE0A32 (resized).jpeg0859DC46-33F8-4CBF-9548-54233DEE0A32 (resized).jpeg70F8CDFD-BDFD-4CCD-BE77-CB08E82993FF (resized).jpeg70F8CDFD-BDFD-4CCD-BE77-CB08E82993FF (resized).jpeg1942ED56-CF19-48A2-ADC3-25E251B4ADFC (resized).jpeg1942ED56-CF19-48A2-ADC3-25E251B4ADFC (resized).jpeg1CA6AA3B-8849-451D-8DF4-DEA124E6AA49 (resized).jpeg1CA6AA3B-8849-451D-8DF4-DEA124E6AA49 (resized).jpegF570E69C-3DED-423A-B506-52ED8D9C4CF9 (resized).jpegF570E69C-3DED-423A-B506-52ED8D9C4CF9 (resized).jpegE22D9C4A-00AF-4093-BF8B-817A742B2A20 (resized).jpegE22D9C4A-00AF-4093-BF8B-817A742B2A20 (resized).jpeg
#4133 4 years ago
The first relay is for the visor motor.
The second relay is for the GI lamps.
The last relay is the A/C relay. The solder connections look fine.
If you put the game in coil test and stop on solenoid #14. Do you hear/feel this relay clicking?
#4134 4 years ago
Quoted from GRUMPY:
Yes, I feel the relay clicking fine. All of my C sides are not working, including the knocker. Do you think it maybe something at the MPU, that controls the ac relay?
#4135 4 years ago
Nope, it will the relay it's self. If you can get the cover off to look the contacts, is there any dirt or dead bugs in there?
#4136 4 years ago
Quoted from GRUMPY:
I never had any luck getting those old yellow covers off. Suggestions for that? Heat?
#4137 4 years ago
Quoted from GRUMPY:
I’m going to replace it with a new one on hand and see if that resolves the issue. Fingers crossed. I’ll let you know how I make out. Thank you for the help!!
#4138 4 years ago
Just the relay or the whole board?
#4139 4 years ago
Quoted from GRUMPY:
Just the relay
#4140 4 years ago
Just the relay
The ac relay ended up being the culprit. After finally getting the old one off the board, soldering a new one in place... fired it up and I have all my C side functions working properly. The old relay looked good inside but something wasn’t doing its job.... glad I got it running. Thank you for the help!!
#4141 4 years ago
Anyone see the recent pinbot listed? Absurd pricing.
Look at coin door and bonus multiplier decals.
Some people are crazzzzy....
#4142 4 years ago
Playball!!
#4143 4 years ago
Quoted from Blackbeard:
"I believe their is no Pinbot more beautiful than this one."
Guess he doesn't get around much.
#4144 4 years ago
If it’s towards the top it’s been re listed. I saw it the first time several weeks ago when it was posted and thought to myself, wow it does look good. But there’s not a Pinbot in existence that’s going to fetch near that much.
#4145 4 years ago
Quoted from Jmckune:
You gotta zoom in on the pics. The bonus multiplier decals are all messed up. And theres wear all over.
For that price you'd think you'd at least have a repro pf.
What a joke.
SIDE NOTE: how you liking that taxi? LOVE mine.
#4146 4 years ago
It is incredibly nice, but it's hard to pay that much for a machine that typically costs under 1/2 that amount.
He lives close to me and it had been up for sale for quite some time now.
#4147 4 years ago
“I believe their is no Pinbot more beautiful than this one.” Price- $$WTF$$
<walks to gameroom, looks at Pinbot, remembers paying $750 for it>
Nope, can’t agree with that at all, and, yes, “there” is one more beautiful than that.
#4148 4 years ago
I’ve resorted to going and playing the one at the local barcade. Mine is still sitting in the garage in the moving configuration. Dads been helping me renovate my house and he got the flu. We’ve made no progress in the past week and until the bathroom is put back together I can’t live there because the old water shut offs were no good so we had to turn water off to whole house so my Taxi is taunting me, folded up, unable to be played yet because I don’t have a spot that’s ready to set it up as after the bathrooms done going to sand and refinish hardwood floors.
#4149 4 years ago
Quoted from Daditude:
I disagree.
If you look at the pf up close you’ll see wear. And those multiplier decals. Ugh
It’s a 2500 pinbot tops.
#4150 4 years ago
Quoted from GRUMPY:
Hey GRUMPY i was able to get over and cut the leg. I still get 2.1VDC once it is severed. Also I read 2.1VDC on the cut leg (input).
What should I do next?
3,000 (OBO)
Fargo, ND
$ 2.50
Lighting - Backbox
Twisted Tokens
$ 69.00
Pinball Pimp
$ 36.95
3,152 (OBO)
Pulaski, PA
$ 39.99
$ 29.95
PinBoss Mods
$ 18.00
$ 35.99
West Chester, PA
3,750 (Firm)
Clovis, CA
$ 175.00
Professor Pinball
$ 95.00
Pinball Mod Co.
$ 18.95
This page was printed from https://pinside.com/pinball/forum/topic/pinbot-fans-and-owners-club/page/83 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
