(Topic ID: 70838)
Pinbot Fans and Owners Club!
By wayout440
5 years ago
  • 3,899 posts
  • 334 Pinsiders participating
  • Latest reply 39 minutes ago by Bospins
  • Topic is favorited by 169 Pinsiders
There have been 1,075 images uploaded to this topic. (View topic image gallery).
There are 3899 posts in this topic. You are on page 78 of 78.
#3851 36 days ago
Quoted from Blackbeard:
Guys I need to order some
White gi bulbs from comet today. I HATE the red/blue ones in there now.
Which ones look good? Frosted?
Normally I use the sunlight frosted for 90% of the game I install LEDs in. That is all except for space games. I think the cool white frosted give it a cleaner space look.
#3852 36 days ago
Rygar
Don't know if you found an answer yet, so here you go.
DSCN3628 (resized).JPGDSCN3629 (resized).JPGDSCN3630 (resized).JPGDSCN3631 (resized).JPGDSCN3632 (resized).JPG
#3853 35 days ago
Quoted from Billc479:
Rygar
Don't know if you found an answer yet, so here you go.[quoted image][quoted image][quoted image][quoted image][quoted image]
Thank you! I really appreciate it.
#3854 35 days ago
Quoted from Tomass:
I prefer frosted. I think they have 3 levels of brightness and I go with the middle (sun?) But that is personal preference.
Quoted from FLASHBALL:
I agree with Tomass I really like the look of the comet 2smd sunlight frosted. Just bright enough to not be yellow and also that its not completely blinding when exposed.
Comet pinball
Sunlight white frosted
25 or 100 pack, depending on how many you need
#3855 32 days ago
I'm three wires away from finishing fixing up pinbot. Could someone post some pictures of the wiring on the right side inlane and outlane? I've got two green/red wires that I assume connect to the inlane switch (color is correct to manual). Then I have a yellow wire connected to the outlane switch. I'm assuming that this should also be a green/red wire and connect to the inlane switch?
IMG_20191011_121324 (resized).jpgIMG_20191011_121342 (resized).jpgIMG_20191011_121354 (resized).jpg
#3856 31 days ago
Here ya go willathrilla
#3857 31 days ago
Quoted from Willathrilla:
I'm three wires away from finishing fixing up pinbot. Could someone post some pictures of the wiring on the right side inlane and outlane? I've got two green/red wires that I assume connect to the inlane switch (color is correct to manual). Then I have a yellow wire connected to the outlane switch. I'm assuming that this should also be a green/red wire and connect to the inlane switch?[quoted image][quoted image][quoted image]
Definitely show it off when it is up and going!
10
#3858 30 days ago
Thanks guys! Fully working now!
Pinbot circuits activated!
#3859 28 days ago
New to the club!
#3860 28 days ago
Welcome to the club
#3861 28 days ago
Ok so only had the machine for 2 days and I have some questions. All my displays are not working but game plays. I was wondering a few things.
Online I see that Jupiter always flickers, what is the significance of this ?
Who sells a good decal set ? I’m going to cut a new uppermost cap section that goes above the visor on the laser table and I need a sticker for the new one.
#3862 28 days ago
Quoted from wolffcub:
If you reach jupiter it is a special "free credit"
#3863 28 days ago
Quoted from Tomass:
I think i should spend more time getting intimate with the manual. This is prob noted in the black and white lol.
#3864 28 days ago
...All my displays are not working but game plays....
None of your displays are working? If so, check F1 on the power supply before you do anything else? F1 is the high voltage fuse that supplies power to the displays.
If some of your displays are working, that is going to be a different problem.
///Rich
#3865 28 days ago
all are out. F1 was fine.
#3866 27 days ago
Check the power supply for the positive and negative 100 volts.
#3867 27 days ago
im getting wacky numbers at the orange and brown pins at the control board.
#3868 27 days ago
Quoted from GRUMPY:
Check the diode for this lamp.
I bought the multimeter and check this diode. Something seems to be wrong with this diode. Can you advise me what is the specs of this element? What kind of diode should I look for and buy?
I explain my problem:
The problem referred to the 5x5 grid has occurred - one of LED's lights stopped shining. I checked the LED lamp and found everything is fine with it.
#3869 27 days ago
I get these, since they can be used in a lot of places. You could also get the 1N4004.
https://www.marcospecialties.com/pinball-parts/1N4007
#3870 27 days ago
Quoted from lecter:
These can be used for any 1n400x diode on the game, so buy one kind and done.
#3871 27 days ago
Make sure your DMM is set to DC volts and the black lead is on ground. Then test pins 3 and 4 for voltage.
#3872 24 days ago
Hi guys! Just picked up a nice pinbot last week w/full topside tear flip rebuild etc.
A couple quick questions.
It came with a good translite, was pinbot originally run w/both translite and black glass?
Did CPR run pfs and plastics etc on this one recently? Other than a chipped plastic near visor I’m ok, but was just curious.
Plays great- Thanks for input!
#3873 24 days ago
Quoted from Vino:
Plays great- Thanks for input![quoted image]
Pinbot only came with a translite. It's very well done and looks like a screened glass. CPR does have a screened glass, but that's not factory.
Not sure when they did playfields, but CPR has plastics available now.
#3874 23 days ago
Looking for rear plastic helmet that goes over blue ramp and multi-ball robot. Also 2nd player display and wire form ramp from upper playfeild to right in lane
#3875 23 days ago
Anyone have a spare right hand control room plastic? My machine is missing this one piece and I'd rather not buy a whole set just to get this one piece.
#3876 16 days ago
Quoted from ArcadeRaid:
Anyone have a spare right hand control room plastic? My machine is missing this one piece and I'd rather not buy a whole set just to get this one piece.[quoted image]
I do but it has a 2 inch scratch on through the flag..
#3877 16 days ago
Quoted from Vino:
Marco has plastic sets
i have one in decent condition if you want it
#3878 16 days ago
Thanks, when I didn't hear anything in a week I just went ahead and bought one I found online. Thanks though!
#3879 15 days ago
My current cabinet is trashed. I need a system 11 cabinet for my Pinbot restoration. Anyone have leads?
#3880 15 days ago
Quoted from Toucanf16:
Kirk Weaver out of northwest ohio was making cabinets. That may be a place to start.
#3881 11 days ago
Quoted from GRUMPY:
GRUMPY and ChrisPINk25 - it works! Thank you very much for you advices!
#3882 11 days ago
You’re welcome! I learned from the pro, grumpy
#3883 8 days ago
My game is having some sounds issues. Seems like overlapping sounds and static on occasion. I replaced all of the caps on the sound board and it doesn't happen as often but it still happens. Any suggestions? Thanks
#3884 6 days ago
When i got the machine i knew something was done as a fix from the previous owner but it was difficult to see exactly what it was. Looks like road signs can be repurposed into pinball replacement parts. Put some new plastics on yesterday, its nice to see the eye socket light show properly again.
#3885 6 days ago
Pretty clever if you ask me
#3886 5 days ago
When i got the machine i knew something was done as a fix from the previous owner but it was difficult to see exactly what it was. Looks like road signs can be repurposed into pinball replacement parts. Put some new plastics on yesterday, its nice to see the eye socket light show properly again.[quoted image]
Good one for the hacks thread!
https://pinside.com/pinball/forum/topic/worst-hackrepair-you-ever-saw
Theres some pretty humorous hacks in there!
#3887 5 days ago
Quoted from Strummy:
Suggestions on this would be appreciated
#3888 5 days ago
How’s your ps cap situation?
#3889 4 days ago
Ps? power source?
#3890 4 days ago
Ps? power source?
PS = Power Supply
The board in the backbox that looks like this. Are your capacitors old? Have they ever been replaced? What is your voltage at the test points?
#3891 4 days ago
Ps? power source?
Yes. Likely needs rebuild. Post pic.
#3892 4 days ago
Has anyone installed the mirrored mini-playfield that’s on eBay? How does it look on the game? How has it held up after hundreds or thousands of plays? Is it worth the asking price?
ebay.com link
84222878-4BF7-48EB-A413-7FE1450D658C (resized).jpegD71AEB91-2309-4826-8A50-D575A58A270C (resized).jpeg
#3893 4 days ago
Wow, since it is back lit I don't think the effect would be all that pronounced. I would need to see it in a game.
#3894 4 days ago
PS = Power Supply
The board in the backbox that looks like this. Are your capacitors old? Have they ever been replaced? What is your voltage at the test points?[quoted image]
They are probably old as most parts on this game. Ill check it out. Thanks
#3895 2 days ago
Quoted from Blitzburgh99:
ebay.com link[quoted image][quoted image]
I have it installed in my game with a black Jack*Bot ramp. It is a personal taste thing. These were made by CPR a couple different times and are top quality. You can get the normal issue one for about 1/2 price from their website.
https://classicplayfields.com/shop/pinball-plastics/pinbotmini/
#3896 1 day ago
I have a mirrored one and you cant really tell its mirrored during game play.
Its aging perfectly fine.
#3897 6 hours ago
Hey Everyone
Just got myself a pinbot over the weekend. My 7 year old son is doing his best to single handedly double the number of plays on the thing. What a great game.
Question - someone replaced all the displays with pinscore ones, not sure how long ago. They're working well except the top row of displays won't show the bottom right diagonal segment in any of the digits...in other words, Rs look like Ps (JUPITER looks like JUPITEP)
I suspect a faulty ribbon cable but before I go troubleshooting, thought I'd check with you all and see if you've experienced this and could suggest a likely root cause.
#3898 6 hours ago
Have you tried re-seating the ribbon cable on that display? Mine was acting up the other and doing that corrected the problem.
#3899 39 minutes ago
I swapped ribbons around and that worked. I think I just need new ribbons. Not urgent. Game needs some cosmetics but is actually playing great.
$ 99.00
Pinball Sales
$ 14.00
Yorktown Parts and Equip
2,999
Sale Pending!
Richfield, MI
3,100 (OBO)
Mechanicsville, VA
