(Topic ID: 70838)
Pinbot Fans and Owners Club!
By wayout440
9 years ago
  • 5,745 posts
  • 446 Pinsiders participating
  • Latest reply 2 hours ago by Billc479
  • Topic is favorited by 225 Pinsiders
There are 5,745 posts in this topic. You are on page 113 of 115.
#5601 77 days ago
Quoted from Robotworkshop:
Can you post pictures on how the wires for the sound are plugged in? Also of the Rottendog board.
The photo dump, as promised.
Condition of old MPU after a lot of attempted cleanup, with (original?) ROMs sitting on top:
Sound board. The ROM was actually "Music / Spch" which potentially blows my theory that it was that chip, since speech works.
Rottendog CPU:
Rottendog 11A Audio Module:
The area below that in case it's relevant:
#5602 77 days ago
Quoted from Gornkleschnitzer:
Rottendog CPU:
That is an early version of the Rottendog board. The newer one doesn't have that daughter board and also has a couple different precision multiturn potentiometers to adjust the sound section. I don't believe that one has any of the sound issues you describe.
#5603 77 days ago
Interesting information, thank you! If for some reason I can't get my spare MPU running properly, I may end up getting the newer version.
#5604 77 days ago
Quoted from GRUMPY:
the legs are bent like this for a reason
Many years ago I was told by an engineer from Mettler/Toledo that IC legs are flared to make assembly easier as it keeps the chips in the holes when the boards are turned over for soldering. Since the vast majority of DIP ICs end up soldered rather than socketed I have never questioned this information.
However, your suggestion that the leg flare is designed to keep the chips in their sockets sounds reasonable too. Since I am always interested in correcting my misconceptions I did a little bit of research this morning, consulting data sheets from modern and old EPROM chips, DIP sockets, as well as googling random Internet discussions of this topic. The only information I found, however, is some support for the through-hole soldering argument, a suggestion that the flare makes it easier to build stuffing robots, as well as claims that not all IC leads are bent outward and that some high-value chips in particular use vertical legs.
I would appreciate any pointer to better technical information on ICs and sockets.
#5605 65 days ago
I just picked up a PinBot and it has a ‘feature’ I hadn’t seen before.
There’s a wire ball guide / habitrail that goes from the bagatelle area to the left inlane.
The inlane plastic looks like it’s been trimmed a little. Pics on IPDB show that plastic cut similar to the right inlane to allow a ball to drop - so maybe it was a planned feature?
Does anybody else have this?
C2F3941C-ABB4-4FD6-B596-A0AFABDCCD29 (resized).jpeg6EAC6C67-CEED-4953-90DB-9BD0BEE60040 (resized).jpeg033E9841-E149-469F-B395-A73CF87C10D7 (resized).jpeg
#5606 65 days ago
Quoted from MadMaxDad:
Does anybody else have this?[quoted image][quoted image][quoted image]
I think I recall seeing a post where someone added that. Nothing factory that I am aware of.
#5607 65 days ago
I made one like that for my machine but i used copper romex wire inside a blue nylon housing for the rails.
#5608 64 days ago
Wow this is cool! Might have to implement this on mine…
#5609 64 days ago
I'm having a heck of a time finding switches for my Pinbot. Specifically SW-1A-164 for the entrance and exit to the ramp. Searched a lot of sites (Marco, Action Pinball etc.) Nobody has them in stock. Can someone direct me to a supply or solution? I thought about trying to just get the reeds and building my own. Any suggestions? Thanks.
#5610 64 days ago
Quoted from Wizbangdoodle:
I find Pinball Resource has lots of parts not available elsewhere. You should give them a call or send them an email. You cannot search their website or order online. But they have never let me down.
///Rich
#5611 64 days ago
The magnet switches by M&M Creations are a much more elegant solution than those factory switch stacks, especially if you use one of Freeplay 40’s translucent ramps.
https://pinside.com/pinball/forum/topic/mampm-creations-mrs-catalog
#5612 63 days ago
I ordered MRS switches as well for my ramp and love them. I do have the old switches if you are interested in them. I will probably never use them again but I do not have the brackets for the switches.
#5613 63 days ago
That's the lame mod, for people who can't handle ball drains.
#5614 63 days ago
Quoted from pinballizfun:
What do you mean?
#5615 63 days ago
Quoted from dddanielll:
What do you mean?
some guy here created it because he was whining that the ball could come off the side of the upper PF (as it was designed to do), and sometime drain if not nudged. So he "fixed" it by adding a ramp to take away the already rare drain scenario. He "fixed" something that was not a problem and made the game easier on himself. Might as well blocked the out lanes while he was at it.
#5616 63 days ago
Hmm seems to me more like a cool way for the ball to return to a different flipper after hitting the ramp.
#5617 63 days ago
The design of that crossover ramp looks very flawed to me. First of all, there is nothing to guide it on the wire form. I think most balls would just fall to the playfield instead of riding the wires. The second problem is dropping off to the in-lane. There is nothing there preventing a fast rolling ball from just rolling across the slingshot plastic to the out-lane.
#5618 62 days ago
Quoted from Mad_Dog_Coin_Op:
The homebrew one I made years ago has a ball catcher to prevent that.
When I came up with the idea for mine (see photo) it had nothing to do with ball draining. I liked the idea of the upper playfield being able to deliver the ball to either flipper lane and thought a cross-playfield habitrail would look cool. Just personal preference that I'm sure many others will despise.
#5619 62 days ago
Just got done playing a few games with my PEMBOT game roms and I really enjoying the gameplay! Brings a new set of rules and stays true to the original! I would highly recommend giving it a try!
#5620 61 days ago
Quoted from sethbenjamin:
Thanks for posting those. I'm tempted to get a set for the ramp simply because adjusting the leaf switches is a pain in the ass since you can't do it with the ramp in place. Real trial-and-error, mostly error, in that process. Seems like the exit switch is very intermittent on mine, which is not cool.
Richard
#5621 61 days ago
Quoted from someotherguy:
Richard
I bought a new ramp and put the old switches on and I was having issues with the exit ramp going off all the time. The MRS switches fixed that and they work great! Get them you won’t regret it!
C5A01D51-4E08-4E01-9C73-59433F91B054 (resized).jpegD4743764-8165-4CD5-8E17-BB69C9AF157D (resized).jpeg
#5622 61 days ago
Quoted from waletboy:
That first pic makes the red post look oddly like a little Lava lamp was added to the game.
#5623 61 days ago
Had a good game today, could have clocked it with another solar but wanted the highest score.
3BAB28E4-80BD-470B-9561-07DD5D681EC7 (resized).jpegAB55E84A-F002-48FD-A47C-55962318BEEC (resized).jpeg
#5624 61 days ago
Quoted from RichWolfson:
///Rich
Thanks guys, all good info. Now to search for some plastics.
#5625 61 days ago
I could even make a ramp for Pinbot without the roll-over switch cutouts if the magnetic switches were going to be used.
#5626 61 days ago
Quoted from Freeplay40:
You make a red/blue ramp with magnet switches, connector plugin pigtail with all flashers and stickers installed, a true drop in replacement, then put me down for 1. I like the look. But if it ain’t broke… my original is in great shape, so motivation is low, but if it drops in and works, then ok, give me one. But currently not got the time to move hardware from old to new and remanufacture as needed, looking for more turnkey solutions since diagnosed with the big C. Using my time to play pins more than refurb/mod/restore these days.
#5627 61 days ago
Quoted from Lostcause:
Had a good game today, could have clocked it with another solar but wanted the highest score.[quoted image][quoted image]
Turn on unlimited extra balls and play forever… I quit at my fifth rollover.
#5628 60 days ago
I finally installed the red/blue ramp I bought from you a while back. Fits and looks great! Just wish I had some clear decals for it.
#5629 60 days ago
Quoted from Bublehead:
Wow need to set this up hard then, only had it a few weeks. Maybe get a blindfold lol
#5630 60 days ago
Let everything auto percentage and watch your timers fall to nothing… my drop timer was like something stupid low at one point… kind of fun to watch how it flexes to meet percentages. Put it on hard and try to get to the sun… if your a masochist, or tell your friends your turned it on easy if you’re a sadist
#5631 60 days ago
I've found over the years that nothing makes me get bored of a game more than if it's way too easy. It's why I used to churn through a game in 2-3 months and swap it for something else. Loose or no tilts, everything set either factory or easier. Boring.
Now I set everything up like it's at a tournament. The casual people who play don't notice (they don't shake) and they don't know the settings. Keeps the ball times really low and the interest/challenge levels high.
#5632 48 days ago
All,
My (recently purchased) PIN*BOT's knocker doesnt strike when a match is made, the knocker works (on test etc), is it because its on free play? And the match sequence seems to work etc (topper lights flash etc)
I've looked through the manual, other than turning the match feature on or off (it is ON), doesn't seem to be anywhere where I can manually prevent the knocker from activating on match or not.
Any advice, I would much prefer to hear the sound, whether or free paly or not.
Thanks,
#5633 48 days ago
One other question...
My ramp enter switch (switch 40) was not registering, after some trouble shooting seems like it is the resistor between two contacts - Ive bypassed the resistor for now and wanted to know:
-What is the resistor there for anyway? I notice almost all electrical components under the playfield have em.
-What risk is there to run the switch without one?
-Any one know the resistor value to replace it? is it listed in manual?
#5634 48 days ago
That's not a resistor it's a diode. It's required. It's a 1n4004 diode. All switches in a switch matrix need them although they are left off of coin switches sometimes (which is bad if the switch gets stuck on)
Some switches will have a resistor and capacitor on them, those are the special activation switches on the pops and slings.
#5635 48 days ago
Ah ok, I understand now, one way voltage switch. ok
Ill replace this asap...do you happen to know what type of diodes are used on the flippers? I'm getting flickering on some LED flashers, I believe the flipper diode needs to be replaced?
I'll check manual too...
#5636 48 days ago
Quoted from Cariba:
1n4004 also but you can just get 1n4007's they will all work (higher voltage capacity)
#5637 48 days ago
Quoted from Cariba:
Correct, with that being said you need to install them in the correct direction. You need to look at the old diode's silver band and install the new diode band the same way.
#5638 48 days ago
Quoted from GRUMPY:
Ah yes ok thanks for that.
#5639 43 days ago
Hi
Anyone convert to led displays and have 2 working lower numeric displays they would like to sell. Please pm me
#5640 43 days ago
So can anyone confirm why my knocker doesn't hit when a match is made? is it cause its in free play? Cause I'm using PEMBOT? the knocker works for all tests etc.
much appreciated,
thanks,
#5641 42 days ago
Quoted from Cariba:
much appreciated,
thanks,
I am running PEMBOT and on free play. I believe mine does the same on matching no knocker but high score and replay it works. I will confirm and get back to you when I match a game again.
#5642 42 days ago
Quoted from mike200mph:
Hi
I sold mine when I converted to LED. Honestly do the conversion and never have to worry about it again and they look great!
#5643 42 days ago
Yes, I noted yesterday that the knocker did in fact work on replay score achieved. I'm still left wondering if the knocker not actuating on a match is a symptom of PEM*BOT or free play setting?
Anyone else can confirm?
#5644 42 days ago
Quoted from Cariba:
That's a PEMBOT bug, unfortunately. It will be fixed in J-3. In the mean time, please PM me your email address so that I can send you an updated version for testing.
#5645 41 days ago
Quoted from idealjoker:
Ah ok thanks for confirming and letting us know. There was another issue I experienced with getting a high score, that I ended up having to reset the machine. I thought I read about that on another post or thread, but I recall it was about the music (not playing?) for reaching new high score, whereas the music played for my instance, but some other issues arose. I can PM you with more details.
Regards,
#5646 39 days ago
I could use a little help. My Pinbot has been very reliable since I got it about 10 years ago. I had just played it this past weekend and was going to take it to MGC in a couple of months. I turned it on tonight, and in the middle of the game, the flippers died, displays went out, and the music kept playing. Any ideas on where to start troubleshooting? Thanks.
#5647 39 days ago
Quoted from floyd1977:
Sounds like you need to rebuild the power supply. If you test the 5 volts at the cpu, what do you get?
#5648 39 days ago
Quoted from GRUMPY:
About 4.3V. I'm guessing that's not good, ha!
#5649 39 days ago
Quoted from GRUMPY:
By "rebuild the power supply", that means board work right? Sorry, I can fix most mechanical things but have not had to do much on the electronics side other than replace transistors, a BR, etc. If this is board work, maybe Borygard could give me a hand. He's usually at MGC.
#5650 38 days ago
4.3 volts is way low. Problems start happening at 4.86 volts and lower. At a minimum you need to replace the electrolytic caps, maybe the voltage regulator and the bridge rectifier.
$ 29.95
PinBoss Mods
Toys/Add-ons
Gweem's Mods
Sound/Speakers
3,000
West Point, UT
$ 12.00
Lighting - Backbox
Twisted Tokens
Backbox
Other
2,250 (Firm)
Jacksonville, FL
$ 52.99
Pinball Shark
Shooter rods
$ 69.99
Pinball Shark
Shooter rods
This page was printed from https://pinside.com/pinball/forum/topic/pinbot-fans-and-owners-club/page/113 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
