So all three (newer) LED lamps on the drop targets are burned out, in fairly close succession. Random freak occurrence or symptomatic of a larger problem?
You could have a bad transistor that drives that row/column. I would try 3 44 lamps and see if they are abnormally bright. If they are a transistor may be shorted.Also make sure the drop target coil lug is not rubbing on lamp socket.
Quoted from pinballplusMN:You could have a bad transistor that drives that row/column. I would try 3 44 lamps and see if they are abnormally bright. If they are a transistor may be shorted.Also make sure the drop target coil lug is not rubbing on lamp socket.
Thanks! It's a partial cloumn, as the chest matrix lamps downstream still light. The 44 lamps test is a great suggestion. And yes, the coil is placed ridiculously close to the sockets! No rubbing upon initial inspection.
This page was printed from https://pinside.com/pinball/forum/topic/pinbot-drop-target-lamps-mystery and we tried optimising it for printing. Some page elements may have been deliberately hidden.
