I recently purchased a Pinbot with a missing display and the center segment "g" not working on the numeric displays. I decided to purchase an Xpin replacement led setup, incorrectly assuming this would cure both of my issues. The segment issue continued.
So far, I have:
Swapped around the ribbon cables to make sure it wasn't one of them.
Checked for voltage and continuity at IJ1 and IJ2 between the main and display boards. Re-seated all connections.
Not sure where to go from here. (I am rather new to this) If it is the cpu I will send it out for repair just want to make sure I am not missing something simple.
Anyone have suggestions?
