(Topic ID: 142835)
Pinbot Bright digit on seven segment display
By waynestatemac
8 years ago
  • 4 posts
  • 4 Pinsiders participating
  • Latest reply 8 years ago by falco
#1 8 years ago
Members,
I need some help with my Pinbot! First off I had a perfectly working display on my Pinbot prior to this issue. The issue arose when I was repairing a spare 7 digit display panel that had a pin broke on it that controlled the B segments on the display. I was testing my fix of the pin on my Pinbot’s player 4 connector. I’m not sure what I did, I’ve been working long hours at work and have a newborn at home, so in my daze maybe I accidently connected the ribbon cable backwards or something but now when I plug in the spare display into the player 4 ribbon cable I get the UNITS digit, which is the first number, super bright and the rest of the digits on Player 3 and Player 4 under the normal brightness. On the original player 4 display if I plug that in the Units digit is super bright and the rest of Player 4 digits normal and Player 3’s digits are to dim to see. I tried 2 different ribbon cables and the same thing happens with both.
Months ago I did the zener diode mod to lower the voltage for the displays which I think left the voltage around 94v and -94v. I wasn’t able to test the voltage yet but I imagine it’s still the same as the Player 1 and Player 2 displays work just fine and are the same brightness as before the issue. I had some spare power supply capacitor kits laying around so I installed new capacitors for C1, C3, C10, & C5 as I think those all deal with high voltage display. After the cap install the displays acted the same with the bright unit digit on player 3. I think I damaged something on the Alphanumeric Master Display Board but can’t see anything. Could somebody lend me an idea of something I should look for? Too me it appears that the unit digit is getting higher voltage then all of the other digits for Player 3 and Player 4 and hogging all the power.
Thanks,
Mike
#2 8 years ago
Some digit driving information that might help
See sections:
"Partial Segment Failures on Score Displays"
and "More Segment Problems: the UDN7180 chip"
http://techniek.flipperwinkel.nl/wms11/index3.htm
#3 8 years ago
try connecting the player 3 display to player 4 with nothing connected to player 3 and see if it works as it should, if it does you may have 2 faulty glasses
#4 8 years ago
Random guess time - I've seen a similar thing before due to a failure in digit selection logic. What was happening was, the bright digit was selected all the time, so whenever one of the other digits had a segment enabled, that would add to the brightness of that segment on the bright digit. I forget the exact failure, but after working that out, and tracing the selection failure back, it was easy to solve. Unfortunately I don't have access to my pinball gear right now, or I'd have a look for likely candidates for you. If it isn't resolved by the time I'm home (couple of weeks), I can see what I can figure out.
$ 39.99
$ 175.00
Professor Pinball
3,750 (Firm)
Clovis, CA
$ 29.95
PinBoss Mods
2,550 (OBO)
Bethlehem, PA
$ 54.99
$ 2.50
$ 35.99
$ 18.95
$ 69.00
Pinball Pimp
Lighting - Backbox
Twisted Tokens
3,152 (OBO)
Pulaski, PA
$ 95.00
Pinball Mod Co.
$ 18.00
2,800
West Chester, PA
$ 36.95
This page was printed from https://pinside.com/pinball/forum/topic/pinbot-bright-digit-on-seven-segment-display-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
