Switches work in test as well. Not sure what to look for, any thoughts?
Can you describe the problem a little more specifically? You press start button, game starts but no ball kicks out? Or is it one or more saucer kickouts that isn't working?
Shooter lane switch stuck?
http://www.pinballrebel.com/pinball/cards/Tech_Charts/Williams_Pinbot_Tech_Chart.pdf
Quoted from Brtlkat:Correct # of balls installed, trough switch's working correctly when one ball at a time are loaded?
There are two balls installed.
Quoted from YeOldPinPlayer:Can you describe the problem a little more specifically? You press start button, game starts but no ball kicks out? Or is it one or more saucer kickouts that isn't working?
Push start and the ball does not eject into the shooter lane. I checked the trough switches and they all activate in test mode just fine. The shooter lane switch is also OK. Actually, there are no stuck switches in test mode at all.
Do any coils fire when you hit the start button? Is the game actually starting? If no music and no coils firing then the start button might be malfunctioning.
If not one of your trough switches is off.
This page was printed from https://pinside.com/pinball/forum/topic/pinbot-ball-eject-works-in-test-not-in-game and we tried optimising it for printing. Some page elements may have been deliberately hidden.
