Hello with the release of venom coming up comes a new Pinbawlers deLuxE armor design for venom.
https://pinside.com/pinball/market/shops/1463-arcade-cabinetscom/08995-pinbawlers-deluxe-armor-pre-order-sept-w-venom-
Pre-preorder for this plus all my others ends September 3rd
The new Venom design is curve somewhat to the shape of his head sporting huge WHITE eyes and shiny silver teeth (hard to tell the white and silver out in the picture as the light was right above it) The design is subject to change a bit, I probably will make the teeth bigger and maybe add a red tongue that wraps around the button, I haven't decided yet.
--- standard pre-order information
This is like my normal armor/button wear protectors.
that is they is no adhesive or holes to drill. They are attached by removing the button, 1 rail screw and placing these on, then re-installing the button an recrewing in the rail screw
These are designed to look more like the LE button armor in terms of shape and length..
Each game included 2 button extenders that can be securely placed on the end of the button in case your leaf switches need to be a bit longer)
The process I use to make these is completely different than the normal armor. Therefore it's more expensive (though WAY cheaper than the $249 + shipping Stern armor) and more manual time required so to keep things reasonable I only plan to do these every so often. This is for the "End of may" production run.
These are available in the following designs
Rush
Godzilla
Foo Fighters
James Bond 007
Jurassic Park
Iron Maiden
Avengers: Infinity Quest
The Avengers
Star Wars
Lord of the Rings
Mandalorian
Munsters (pro only)
Elvira house of horrors premium
Teenage Mutant Ninja Turtles
Venom
*** New Design / Games ***
Venom!!!
Gauardians of the Galaxy??? (maybe, if time permits)
