following
Not sure why the printer shop is having trouble getting the instruction cards to be 82x152 mm but the guy asked if slightly smaller would be ok...
Is there something I can have them try to make it right? The cards they made do not fill in the gaps.
Quoted from scampcamp:Not sure why the printer shop is having trouble getting the instruction cards to be 82x152 mm but the guy asked if slightly smaller would be ok...
Is there something I can have them try to make it right? The cards they made do not fill in the gaps.[quoted image][quoted image]
i size them right myself and drop them into a 4x6 white or black background in Photoshop so they get printed as standard photo in any photocenter.
Also, consider not slipping them into the apron slots. Make them a bit larger and use doubled sided tape (just an inch will do in the center). You see the whole card and they don't bow up, especially if you use a heavier paper, or even laminate them like I do.
Quoted from Kerry_Richard:Also, consider not slipping them into the apron slots. Make them a bit larger and use doubled sided tape (just an inch will do in the center). You see the whole card and they don't bow up, especially if you a heaver paper or even laminate them like I do.
That's a great idea. Thanks
Quoted from tonyf1965:Star Trek next generation cards?
Options?
Reach out to Mr_Tantrum
He just made me some custom cards
Options?
Several here: http://www.pinballrebel.com/game/pins/instruction/index.htm
