I bought some that look about the same as yours from harbor freight, they work pretty good but I use them in the basement (cement floor) probably wouldn't work good on anything that's not flat
So the skates raise up between the leg levelers and the bottom of the leg? To put the rear one on, you have to pull the machine out away from the wall it looks like. Are they pretty good?
I have a set I purchased years ago when they just came out...I would NEVER be without a set..it is money well spent!
I also have had a set since they were a new product. Purchased from Marco also. I have owned and moved a pile of games. Excellent product.
Harry Irvin
Quoted from Chet:So the skates raise up between the leg levelers and the bottom of the leg? To put the rear one on, you have to pull the machine out away from the wall it looks like. Are they pretty good?
On most surfaces you can put the skate on the front leg and slide the machine outward to get to the back legs. Worst case is using rubber cups on tile, then you might have to crawl under to put the rear legs up on the skate. Generally if I have a game at a show where there is tile, I only put the rubber cups under the front legs. It keeps players from being able to dance with the machine, but leaves the rear legs free to slide.
I love the skates in combination with a Pinball Lifter. The skates get the machine from point A to point B no matter how many ramps or curbs are involved. The lifter gets the machine in the air and left you take the legs off/on to put the machine into or out of a truck.
This page was printed from https://pinside.com/pinball/forum/topic/pinball-skates-source and we tried optimising it for printing. Some page elements may have been deliberately hidden.
