Quoted from AttilaK:I seen this mod on a machine at the Allentown show and it looks awesome. Just curious if the mod comes pre-done on a blade with the walkers/zombies behind. Hard to tell in the pics. I am debating on getting it as some games can use mirror blades, or maybe even side decals but seems this one is OK with out it. Plus for the money, I think a shaker and subwoofer upgrade may come first for me.
Just to answer your questions:
Yes, the mod is pre-done with the EL wire installed on the fence, you just have to plug in (no soldering required for the installation), the connections for power to the GI lighting and the inverter, then route the wires up through the back side for the playfield, finally set the EL fences in the machine. I have pictured step by step instructions that I email to you after I ship your order. You do have to unplug a connectors at the EL wire to remove them if you need to service the playfield.
The Pingraffix Pinblades artwork is not included in the mod, those are extra.
Thanks,
Steve
Pinball Refinery
