Quoted from pinballinreno:Might need a bit more pigment in the blue lacquer or more coats of dye on the bare wood or both, its kinda light or too transparent, could be deeper in my opinion.
Otherwise its good work.
It's an honest observation. To be clear, dye does not coat the top-side of the wood. It penetrates the fibers of the wood and leaves some surface color exposed. It's not paint, it certainly has a different look, so when we discuss what you want, this is good information to know. And you are correct, more dye in the formula would equate a darker/deeper color. In the full Florida sun as the picture was taken, the color looks light, but the other picture indoors, it's much darker. I believe that under glass and lit by LED's the color will be very rich and even more dark/deep. This batch of dye/lacquer-mix was about 10-12 drops of dye in a small jar of lacquer. I could go for more drops, it certainly would be less coats for me to apply, but this mix seemed to satisfy the customer. Im still adjusting and testing all these options and it's all a learning process. In the end, someone may want the wood/grain to show, others won't. But these results help me learn what I need to do to get the end result. BTW, for any rail that was covered in black vinyl, mostly the late 80's thru the late 90's, the black dye covers about 95% or more of the wood fiber. So luckily there is no issue of tint there.
So with that being said, I am testing some over the counter acrylics that will cover the wood like paint. This 'look' was a common finish for rails in the Bally/Stern classic era. The issue is coating it with a protective and glossy layer of lacquer. If I was to 'paint' the rails with no protection, I think the possibility of them getting worn could be high. Depending on the brand of the acrylic and lacquer, sometimes when they are applied together, they don't work and create issues when curing. So far Im getting good results. So if a 'paint' is wanted(closest to factory color), I can certainty do my best to accommodate.
