Hello,
Game Pinball Pool - Williams Pinball Pool
I have an issue I'm assuming is the solenoid but want to confirm. Solenoids all tested the same...
Drop targets all drop if I hit each target on the right side, as I hit the targets on the right, the left side drops.
However when I hit targets on the left there are two that won't drop the right side corresponding target. If I hit the 1 target the 15 does not drop. If I hit the 4 target the 12 does not drop. Rest of them work.
If this is the issue which solenoids would be the issue? the 12 and 15 or the 1 and 4? Guessing the 12 and 15.... They all seem to have resistance on the coil and test the same as the others.
Any other ideas on things to check?
