What is your thoughts on this topic?
Should Pinball mods void factory warranties? If you think yes which kinds and why?
Depends on the type of mods, if a simple bolt in and removeable type then "no", if using comet bulb adaptors for power or lighting effect then "no" again. But if soldering on boards etc then possibly "yes"
You don't want a cargument here so I'll only say that if I were the manufacturer and you modded your machine don't call us for help.
-Mike
I used to be in the used car business and talked to many people who claimed to be mechanics. Many made the claim but few made the cut. I used to cringe when someone wanted to trade in a car that they had installed a stereo in. The wiring was always a mess and the quality of the installation was always subpar.
Sorry for the cargument but I will 2nd if you mod your pin don't call me for help.
Yes. All non-OEM mods should void the warranty. If it is an official GM, Ford or FCA dealer accessory, then the original warranty remains intact.
I'll go with the following:
Clips in, doesn't connect to power, can be unclipped and leave no trace: No change to warranty. If it came in for repairs, the mod might be removed to get at something to repair, and placed in the cash box for the customer to reattach on their own. Exceptions would be made for things like replacement bumper caps and acorn nuts.
Clips in, ties into GI: Depends on the item and how "marginal" the power ratings are in the game as "stock". If the mod takes advantage of a socket, and can be proven to have less draw than the piece it replaces. Likely would be removed for repair, customer would need to reattach it.
Requires mount added (i.e. drill holes somewhere): Unhappy noise will be made. If it also ties into GI, will void warranty because of the mount requirements. Depending on the mounting method, it might void the warranty even without tying into the GI. Would be removed for repair as best as can, returned to customer to reattach on their own. (You should sense a theme here.)
Replaces electronic function more significant than lighting: Would void warranty. If brought in for repair, mod would be removed, returned to customer to reattach. If mod was responsible for fault, customer would be informed of such, note would be made to add extra surcharge if comes in again for same fault with same mod. Note: it is up to the customer to learn to not to reattach the mod if they lather, rinse, repeat with the mod.
Basically, if it's entirely cosmetic, isn't something that can do damage, and can be removed with no trace, I'd let them keep warranty. If it involves modification or a substantial replacement of part of the machine that isn't just cosmetic, then it's likely the warranty would be voided.
This page was printed from https://pinside.com/pinball/forum/topic/pinball-mods-warranty-should-mods-void-factory-warranties and we tried optimising it for printing. Some page elements may have been deliberately hidden.
