(Topic ID: 239775)
Pinball magic topside teardown.
By Moto_bone
52 days ago
  • 20 posts
  • 9 Pinsiders participating
  • Latest reply 50 days ago by wdennie
#1 52 days ago
To all of you Capcom experts: what is the best method to do a topside teardown to clean and shop? Do you lift it vertical and work in that position?
#2 52 days ago
I would disconnect all connectors from the bottom, lay it back down or pieces will fall everywhere!
check to make sure your optos are all good before you put it back together!
#3 52 days ago
lots of pics during the process. just did this game, reflow solder on all the optos while you have it apart.
#4 52 days ago
Quoted from transprtr4u:
You can't access the back portion of the playfield when it's in the down position. The cabinet restricts access to see what you're doing as well as removing the layers of components.
#5 52 days ago
Quoted from Moto_bone:
You can pull the back of the playfield up and onto the top edge of the back of the cabinet, I think the PF even has some little wheels or something back there to assist with that. It's been quite a while since I've done it so I don't remember the process exactly.
#6 52 days ago
Funny, I'm about to do a topside tear down as well on this game. Any other good advice? I've got to change rubber, some plastics, bulbs, and adjust that pesky feed from the right orbit
#7 52 days ago
Quoted from PinballTilt:
exactly what do you mean by that pesky feed on the right orbit?
#8 52 days ago
Quoted from wdennie:
My outer lane guide is angled to send it straight down the middle. Does anyone know where the feed should go or where yours goes? I'm thinking right flipper
#9 52 days ago
Mine goes to the right flipper very consistently.
#10 52 days ago
Quoted from bobukcat:
I will try that this evening and report back!
#11 52 days ago
Agreex, make sure the game is 100% working prior.
#12 52 days ago
The beauty of Capcom you can pull the playfield out about two feet past the coin door.
Just make sure you support the playfield so you damage the mechs under it
#13 52 days ago
Works like a charm. I cleaned the back ramp and orbit shot tonight. Squeaky clean now! Thanks pinside!!
#14 52 days ago
Yeah, that looks familiar now!
#15 52 days ago
A weak shot to bend the spoon is a design draino. You gotta zing that shot.
#16 51 days ago
Quoted from cody_chunn:
Yea, mine goes straight down the middle too.
I found that on the PF there is a slight ripple right
where it exits the center spoon shot, I can feel it when
running my had across it, and diverts the ball.
I put a PF protector on trying to eliminate the ripple,
but it still goes SDTM.
My question is "is this ripple I feel intended to be there?"
#17 51 days ago
I'll check mine in a few hours.
#18 51 days ago
wdennie no ripple in my playfield. Do you have mylar?
#19 51 days ago
Mine did this when I got it. It took a while to figure out what was causing it, but finally got it. The outer wall metal guide on the right orbit was a bit warped. There was a wave in it which sent the ball toward the center drain. The wave was in the middle of the right metal orbit wall. Here is the kicker: to make the ball deflect less left, you have to bend the metal orbit guide exit MORE to the left. Because of the way it is attached to the playfield by bending the end of the guide to the left, it pulls the middle of the guide to the right and trues up the path. Insert a slotted screwdriver between the end of the metal guide and the metal post (near the hat, has a rubber post sleeve) and pry the metal guide exit to the left. You'll see the center wall of the guide flex to the right. I know it's hard to explain but give it a try.
Ymmv
Craig
#20 50 days ago
thanks caker,
moto_bone yes mine has the mylar on it.
you can't actual see the slight ripple but can feel it.
I thought putting a PF protector on it would smooth out the
effect the ripple was causing, but even with that, it still would change the path.
I did notice that it depended on the speed of the ball how much this would cause the
ball to divert.
I kinda assume with a title pinball magic, the ripple was intended to cause this magical visual
effect.
$ 50.00
$ 45.00
Pinball Photos
$ 399.95
