Quoted from guss:The arm might be put on wrong. Here's a picture of the one I bought.
Ahh I guess that could be the issue as well. I will check that too. Thanks and good eye!
I noticed someone riveted/repaired my stage doors. They don't seem to be available anymore. They are just plastics like the rest in the game so I wonder why nobody is making repros of these. This fix they did is working for now but would be nice to get this back to original one day.
20200324_195323 (resized).jpg@atariaction, what game ROM version do you have in the game? You can see that when you turn on the game. I hope you already have either v1.0.6 or v1.0.12. Anything lower, you definitely can have an issue with the elevator not rising up to the right height. Not sure if older code will affect the wand movements.
Quoted from PinballManiac40:atariaction, what game ROM version do you have in the game? You can see that when you turn on the game. I hope you already have either v1.0.6 or v1.0.12. Anything lower, you definitely can have an issue with the elevator not rising up to the right height. Not sure if older code will affect the wand movements.
Currently running old code but have the latest roms on order!
Screenshot_20200325-111355_Gallery (resized).jpgScreenshot_20200325-111402_Gallery (resized).jpgI like the latest roms because you can disable the buy in feature in the menu adjustments. That was worth the cost alone to me.
Chris
Quoted from Shenanigander:Currently running old code but have the latest roms on order![quoted image][quoted image]
Oh yeah. That must had been you I responded to on Facebook about the game and sound ROMs. Hope you get them soon to see if that at all affects the wand adjustment.
Quoted from SilverUnicorn:I like the latest roms because you can disable the buy in feature in the menu adjustments. That was worth the cost alone to me.
Chris
Ahh good to know! I turn that off on all my games but hadnt tried yet on PM.
Quoted from PinballManiac40:Oh yeah. That must had been you I responded to on Facebook about the game and sound ROMs. Hope you get them soon to see if that at all affects the wand adjustment.
Oh ya probably if you are Brian Thanks!
Quoted from Shenanigander:Oh ya probably if you are Brian Thanks!
Yes. Brian here at your service. I went crazy working on a friend's PM elevator trying to get it to raise to the correct height, no matter how I adjusted it. One day, I noticed the game ROM difference between his game, v1.02, and mine, v1.0.6, and decided to swap the game ROMs at that time. That had fixed his game with v1.0.6. His PM came from Gene Cummingham of Illinois Pinball at the time. Found out those were prototype ROMs installed.
When I upgraded mine to v1.0.12, I did not notice any noticeable difference between v1.0.6, so I left that in his game.
Quoted from PinballManiac40:Yes. Brian here at your service. I went crazy working on a friend's PM elevator trying to get it to raise to the correct height, no matter how I adjusted it. One day, I noticed the game ROM difference between his game, v1.02, and mine, v1.0.6, and decided to swap the game ROMs at that time. That had fixed his game with v1.0.6. His PM came from Gene Cummingham of Illinois Pinball at the time. Found out those were prototype ROMs installed.
Haha nice! How do you know if the elevator is not going to the correct height? Oh wow that is cool. Just watched another mini youtube doc on Gene yesterday. So much history there!
Quoted from Shenanigander:Haha nice! How do you know if the elevator is not going to the correct height? Oh wow that is cool. Just watched another mini youtube doc on Gene yesterday. So much history there!
With the elevator not going high enough, the ball did not come out at the top of that right exit ramp behind the top of the stage.
Miss seeing Gene at TPF and Houston Arcade Expos.
Must have taken the stage assembly apart 6 or 7 times ... changed to the latest ROM and the issue was fixed ...
Elevator worked as should ...
Quoted from PinballManiac40:With the elevator not going high enough, the ball did not come out at the top of that right exit ramp behind the top of the stage.
Ok I see. Mine is working then but still will be updating to the latest roms!
I never met him. Wish I could go back in time and hit up some of the old school expos for sure!
Quoted from transprtr4u:Must have taken the stage assembly apart 6 or 7 times ... changed to the latest ROM and the issue was fixed ...
Wow what a PITA for it to only be code. That stuff drive me bonkers lol!
Quoted from Shenanigander:Hmmmm. Just noticed this bracket hole appears to we worn. Could be part of my problem.[quoted image]
So upon closer inspection that area is factory and not wear. The wand motor works fine out of the machine but still thinking either software or an alignment issue since both left and right motor switches are closed at the same time most of the time in wand test. Also if the wand starts at the right then it does not seem to move over to the left for locking balls. The wand does move in gameplay from time to time but not seemingly correctly.
Quoted from Shenanigander:Wow what a PITA for it to only be code. That stuff drive me bonkers lol
It's always the obvious that is my downfall,....
Quoted from transprtr4u:It's always the obvious that is my downfall,....
Haha. My favorite (and probably everyones) is dropping a small part and then having to look for an hour to find it!!!
Quoted from Shenanigander:Haha. My favorite (and probably everyones) is dropping a small part and then having to look for an hour to find it!!!
Or you don't find it at all....
Quoted from Shenanigander:So upon closer inspection that area is factory and not wear. The wand motor works fine out of the machine but still thinking either software or an alignment issue since both left and right motor switches are closed at the same time most of the time in wand test. Also if the wand starts at the right then it does not seem to move over to the left for locking balls. The wand does move in gameplay from time to time but not seemingly correctly.
Yeah, that mounting bracket/plate did look factory to me. Looks like we'll find out if the new version fixes your wand issue.
I did not test the wand movement in my friend's game since it was a game killer when the ball went into the elevator and was not kicked out to right exit ramp when it needed to. The ball pretty much had to be removed everytime it when in there.
Quoted from PinballManiac40:Yeah, that mounting bracket/plate did look factory to me. Looks like we'll find out if the new version fixes your wand issue.
Yes I hope so! Would be nice!
Ahh I see. Yes that would be!
It's a good feeling when you novus that thick ball trail off the captive ball area!
Not that anyone would, but let's all remember not to use brasso on the wireforms
Don't tighten the nuts all the way down on the wire form in the shooter lane. It will bend the end of it and it will not work. just down far enough so the end of the wire form is not sticking up.
Quoted from guss:Don't tighten the nuts all the way down on the wire form in the shooter lane. It will bend the end of it and it will not work. just down far enough so the end of the wire form is not sticking up.
Hahaha. I wish I knew that before I plunged my first ball and it stuck in the shooter lane wireform. I said WTF! Took me a bit to figure it out.
Quoted from TheLaw:It's a good feeling when you novus that thick ball trail off the captive ball area!
Haha that is the 1st area I cleaned actually!!!!!! Much better. Now I just need a new clear ball!
Sweet thanks so much for the tip! That was a pain to remove especially with the little lamp pbc in the way!
Quoted from epeabs:Hahaha. I wish I knew that before I plunged my first ball and it stuck in the shooter lane wireform. I said WTF! Took me a bit to figure it out.
LOL wow! Crazy.
Quoted from Ericpinballfan:No, you can buy just the shaft and mount larger acrylic ball. I used to sell the larger acrylic captive ball, it worked for the shaft to.
And No....No more acrylic balls left for sale. I made 50 and was surprised how fast they sold.
What are the chances of you making more of your nice balls?
So when you guys pull out the Playfield all the way what are you actually resting it on? In the video posted elsewhere in this forum he mentioned that he thought the Playfield rested on the little side metal pieces but mine are floating and not touching anything. My Playfield actually really looks like it is resting on the two plastic wire bundle holders but I let this coil bracket rest on this tin to relieve a bit of that pressure. How are you guys propping up your Playfield when you pull it all the way out?
20200329_202207 (resized).jpg20200329_202213 (resized).jpg20200329_202232 (resized).jpg20200329_202304 (resized).jpg20200329_202324 (resized).jpgI used a cushioned stool ...
All pins should do this access to the back , when upright you can work both sides
Quoted from transprtr4u:I used a cushioned stool ...
Yes it is nice! Just cleaned up the back of the cabinet last night. So easy to access!
Ok I have a dumb question. The reason my switches aren't working up in the pop bumper ares is that the mounts broke at some point and the "fix" puts them in a different location.
The Manual doesn't call out that mechanical assembly, BUT it looks exact to the slingshot assemblies on the lower playfield (Part A-00157)
Can anyone confirm if they are the same or not? I want to order a replacement but not if it's wrong. LOL
Chris
Quoted from SilverUnicorn:Ok I have a dumb question. The reason my switches aren't working up in the pop bumper ares is that the mounts broke at some point and the "fix" puts them in a different location.
Chris[quoted image]
I am 99% sure they are the same so I have one on order. I will follow up when I receive it
Chri
Quoted from SilverUnicorn:I am 99% sure they are the same so I have one on order. I will follow up when I receive it
Chri
Sorry Chris I was waiting to heat an answer, because I need the very same bracket! Ives just doing some work on mine, and noticed my drop target coil is missing that exact part, pretty random.
Where did you order yours from?
Quoted from TheLaw:Sorry Chris I was waiting to heat an answer, because I need the very same bracket! Ives just doing some work on mine, and noticed my drop target coil is missing that exact part, pretty random.
No worries. Marco had them complete with switches and coil.
https://www.marcospecialties.com/pinball-parts/A-00157
They have a surprising number of parts for Pinball Magic now, including a full plastics set, which I couldn't find anywhere when I needed them.
Chris
Quoted from Shenanigander:Just realized I am missing this post. Do you guys still have it on yours? Should I bother replacing it or is it just going to break off again?[quoted image]
Quoted from Shenanigander:Must be to protect bulbs. I'll stick a post in there!
Probably there to stop the ball getting stuck during Silence the Critics; replace it as Mine's never had an issue
Quoted from TheLaw:Probably there to stop the ball getting stuck during Silence the Critics; replace it as Mine's never had an issue
OK cool thanks. Didn't have correct post but this should work!
20200402_180959 (resized).jpgQuoted from TheLaw:Sorry Chris I was waiting to heat an answer, because I need the very same bracket! Ives just doing some work on mine, and noticed my drop target coil is missing that exact part, pretty random.
I got the replacement and it is the same as the slingshot kicker assembly. That’s a good thing. BUT the replacement has a diode on it and my other assemblies do not. Anyone know if I should leave them on there or remove?
image (resized).jpgQuoted from SilverUnicorn:I got the replacement and it is the same as the slingshot kicker assembly. That’s a good thing. BUT the replacement has a diode on it and my other assemblies do not. Anyone know if I should leave them on there or remove?[quoted image]
Id leave it on and if either switch does not work then just clip it.
Quoted from SilverUnicorn:And I'm an idiot. LOL
Thank you.
To that point - would the resistor make it not show up in the switch test if it wasn’t supposed to be there?
Quoted from SilverUnicorn:And I'm an idiot. .
That's OK, you probably actually know how to spell resistor unlike me
Quoted from SilverUnicorn:To that point - would the resistor make it not show up in the switch test if it wasn’t supposed to be there?
I wouldn't think so...but is it not showing up? does it work during gameplay/test?
Quoted from TheLaw:That's OK, you probably actually know how to spell resistor unlike me
So, when I wired up and installed it the switches "sort of" registered in the switch test, but they seemed delayed or intermittent. Once I buttoned everything up and test played it I got nothing out of them. Now they don't register in switch test at all.
Strange. I double checked my wiring (I added wiring because the wires in the game were too short) and it looks correct to me based on what was in there originally.
Chris
Quoted from SilverUnicorn:So, when I wired up and installed it the switches "sort of" registered in the switch test, but they seemed delayed or intermittent. Once I buttoned everything up and test played it I got nothing out of them. Now they don't register in switch test at all.
Chris
Try clipping the leg of the resistor and see if anything changes. I have also changed some of the wiring on my kicker assembly switches. A couple broken leaf switch tabs, and they used such thin and short wires so I upgraded the gauge and made them longer.
Can someone post or send me a link to a copy of the switch matrix. The IPDB pdf I have is missing it.
None of my left side standups are registering and need to track it down.
Quoted from Black_Knight:Can someone post or send me a link to a copy of the switch matrix. The IPDB pdf I have is missing it.
https://www.ipdb.org/files/3596/Capcom_1995_Pinball_Magic_Manual.pdf
pages 192 and 193
This page was printed from https://pinside.com/pinball/forum/topic/pinball-magic-club/page/36 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
