Quoted from xeneize:Now, to find that plastic.
If you can’t find one let me know may have a spare but just left for Mexico for a week
Quoted from Milk:I am now a proud owner of a ColorDMD in my PM!!! And let me say words can't describe how GREAT in looks!!!
Always glad to hear that!
Quoted from Milk:Here is a Pic of my color dmd. I have a 50 sec. video of it, will figure out how to post that?
Where did you get your apron cards?
Quoted from guss:Where did you get your apron cards?
you can get them from this site
http://www.pinballcards.com/Pinball-Cards/Pinball-Magic
I put one in mine last week and it really does look amazing. I told my wife I'm not sure if it's because it was the only orange DMD I had left in the collection or how good the dots work is on this game but either way I'm super-impressed with it!
Does anyone have under playfield photos of the switches in the pop bumper area? Specifically the left switch for the lower kicker assembly. there is a red wire coming off of that and I need to know where it goes. This is the reason my kicker in that area is not working. I *THINK* it is supposed to go to a 2 wire connector along with the red wire from the other switch.
Can anyone confirm? I hope I explained it correctly.
Edit: Added (borrowed) photo with an arrow and description.
Chris
needs (resized).jpgHas anyone tried fitting LCD ColorDMD? I know the issue is physical compatibility, but how bad is it: would a workaround be possible, or is it near impossible?
Quoted from HighVoltage:Has anyone tried fitting LCD ColorDMD? I know the issue is physical compatibility, but how bad is it: would a workaround be possible, or is it near impossible?
How patient are you?
The colordmd gang is on it now.
Quoted from Milk:Has anybody installed Mirror Blades or side art on there PM?
I'm hoping somebody would make some side Blades. I'm not a fan of Mirror Blades
Can anyone tell me if when the machine is set to free play it is supposed to allow the player to keep buying in after the 3 balls? Is there a setting to disable this or make it only one extra ball?
Quoted from wackenhut:Can anyone tell me if when the machine is set to free play it is supposed to allow the player to keep buying in after the 3 balls? Is there a setting to disable this or make it only one extra ball?
Yes, you can disable the buy-in but I think that it is enabled by default.
Quoted from bobukcat:Yes, you can disable the buy-in but I think that it is enabled by default.
You can disable it if you're running 1.0.12 software. 1.0.3 does not have the option to disable the buy in.
Chris
Quoted from SilverUnicorn:You can disable it if you're running 1.0.11 software. 1.0.3 does not have the option to disable the buy in.
I'm pretty sure you mean v1.0.12, since I linked you to the latest code at Marco to purchase when you updated.
Quoted from PinballManiac40:I'm pretty sure you mean v1.0.12, since I linked you to the latest code at Marco to purchase when you updated.
Yes, sorry. Typo
Corrected
Quoted from SilverUnicorn:Does anyone have under playfield photos of the switches in the pop bumper area? Specifically the left switch for the lower kicker assembly. there is a red wire coming off of that and I need to know where it goes. This is the reason my kicker in that area is not working. I *THINK* it is supposed to go to a 2 wire connector along with the red wire from the other switch.
Chris[quoted image]
Here's a few pics of the switches
20190412_173420 (resized).jpg20190412_173436 (resized).jpg20190412_173454 (resized).jpgNew game ROM can be bought here.
http://www.actionpinball.com/parts.php?item=ROMS242
You need to order both U1L and U1H for v1.0.12
or
Marco also has the U1L and U1H ROMs for v1.0.12.
http://www.marcospecialties.com/pinball-parts/EPROM2080
http://www.marcospecialties.com/pinball-parts/EPROM2079
No. Just a flat head screw driver. Put it under the part on one side and turn the screwdriver a bit, go on the other side and do it a bit at time until it is out of the IC socket.
Quoted from bigfoot53:Here's a few pics of the switches [quoted image][quoted image][quoted image]
Thank you, these helped. Now to pull the game out so I can actually lift the playfield correctly to fix it!
Chris
So I know there has been talk in the past regarding the ball exiting loop 1 and draining. Some have mentioned that the ball is supposed to go to the right flipper. Most of the time, mine actually deflects to the left flipper which is interesting. I think it is caused by a little button screw at the end of the right edge of the exit guide. I have taken a picture and circled it in blue.
B385E8B0-BE88-4026-9421-65C36D971DFD (resized).jpegQuoted from wackenhut:So I know there has been talk in the past regarding the ball exiting loop 1 and draining. Some have mentioned that the ball is supposed to go to the right flipper. Most of the time, mine actually deflects to the left flipper which is interesting. I think it is caused by a little button screw at the end of the right edge of the exit guide. I have taken a picture and circled it in blue.
Interesting. Mine drains probably 80% of the time after the loop 1. It seems to really depend on the speed of the ball as to whether or not it makes it to a flipper or not (no rhyme or reason to it that I can find). Would love to know how to fix it consistently as it seems to be super annoying to players and turns them off of the game.
Chris
Quoted from SilverUnicorn:Quoted from wackenhut:
[quoted image]More
Interesting. Mine drains probably 80% of the time after the loop 1. It seems to really depend on the speed of the ball as to whether or not it makes it to a flipper or not (no rhyme or reason to it that I can find). Would love to know how to fix it consistently as it seems to be super annoying to players and turns them off of the game.Chris
I posted this in a different thread but this worked for me and was not obvious. (It wasn't the rivet/button that caused the drain). Mine now works 100%:
Mine did this when I got it. It took a while to figure out what was causing it, but finally got it. The outer wall metal guide on the right orbit was a bit warped. There was a wave in it which sent the ball toward the center drain. The wave was in the middle of the right metal orbit wall. Here is the kicker: to make the ball deflect less left, you have to bend the metal orbit guide exit MORE to the left. Because of the way it is attached to the playfield by bending the end of the guide to the left, it pulls the middle of the guide to the right and trues up the path. Insert a slotted screwdriver between the end of the metal guide and the metal post (near the hat, has a rubber post sleeve) and pry the metal guide exit to the left. You'll see the center wall of the guide flex to the right. I know it's hard to explain but give it a try.
Ymmv
Craig
Also the wire form that starts the game
The ends get mushroomed i filed mine flat and the improvement was incredible so check the enfs of that ramp
Mine does deflect at the rivet point of the guide, but goes to the left flipper. It is pretty cool though cause it gives it like a magnet affect. I will look and see if anything is waved, but looks too good to have an issue.
Mine right loop always feeds smoothly to the right flipper, fast shots, slow shots, half-way up and back, doesn't matter. Unless it's a shot that somehow goes partially into the silence critics (who doesn't love a cheap award for that on a bricked shot to the right?) and then bounces near the color-changing standup they are always very consistent.
Quoted from wackenhut:Mine does deflect at the rivet point of the guide, but goes to the left flipper. It is pretty cool though cause it gives it like a magnet affect. I will look and see if anything is waved, but looks to good to have an issue.
Mine returns to the left flipper as well and my Pinball Magic has extremely low plays. Cherry playfield and the guides barely have any marks on them. Mine seems factory the way it returns to the left
Quoted from Moto_bone:Mine returns to the left flipper as well and my Pinball Magic has extremely low plays. Cherry playfield and the guides barely have any marks on them. Mine seems factory the way it returns to the left
Agreed...mine is in the same condition, so it must mean something going to the left flipper as being the correct way if both of ours are brand new.
Quoted from wackenhut:it must mean something going to the left flipper as being the correct way if both of ours are brand new.
I think it means the design was imperfect and they only made 1200, so they never really got it nailed down at the factory. Mine is far from worn, but needed the bend tweak. I think the biggest clue is that on machines where it feeds the left flipper, it hops off the rail. I've never seen an orbit shoot that's working right hop of the rail at the last minute.
Ordered my Color DMD today! Excited to have this one in color. Once it arrives will have a great day if fixing things to make this the best it can be!
Chris
First of all I just joined the club! My question is to LED or not LED? I'm a huge fan of led's and I've done them for every game I own and love them. The machine came with an led ocd board not hooked up nut the incandescent lighting gives it a magical effect. Curious if anyone has also felt this way?
Quoted from SilverUnicorn:Ordered my Color DMD today! Excited to have this one in color. Once it arrives will have a great day if fixing things to make this the best it can be!
Chris
I'm glad you did not give up on fixing the game and selling it. It is a different experience with the ColorDMD installed.
Joined the club last week! Found a pretty minty Pinball Magic stuck away in a basement for a long time. Has a total of 2,880 plays.
I have the LED OCD and the ColorDMD on the way!
It's was pretty dirty from the black rubbers that broke down, but after an initial cleaning, it's starting to look nice!
20190422_113529 (resized).jpg20190422_113535 (resized).jpg20190422_113542 (resized).jpgQuoted from comment23:Joined the club last week! Found a pretty minty Pinball Magic stuck away in a basement for a long time. Has a total of 2,880 plays.
Welcome to the club! That looks like it's in great shape! Enjoy!!!!
Chris
So I have noticed that when playing the game, occasionally, when I go to hit a shot with the right flipper it loses its full power causing the shot to be missed. It is pretty strange because it is completely intermittent and works perfect 95% of the time. Has anyone experienced this or would know the cause?
Thanks!!
Color DMD installed, but not without issue. The colorization is just amazing. I am very impressed with how well it was done.
Videos below, both before and after. In the beginning of the "after" video you can see the issue it has now. Any ideas on this?
Before:
After:
Chris
Quoted from wackenhut:So I have noticed that when playing the game, occasionally, when I go to hit a shot with the right flipper it loses its full power causing the shot to be missed. It is pretty strange because it is completely intermittent and works perfect 95% of the time. Has anyone experienced this or would know the cause?
Thanks!!
is the coil getting hot? I know the lotr was notorious for coils heating up and losing some power.
Quoted from PinballManiac40:With power off, reseat the big wide ribbon cable at the MPU and also at the driver board.
No change
It's not THAT big a deal since everything boots and works fine after the messages, but it's just strange.
Chris
Quoted from SilverUnicorn:No change
Chris
Double check the green and white switch matrix wired connectors at the MPU. May have tugged on them swapping out the DMD.
If that is not it, I suggest testing out all the switches in the game.
Quoted from PinballManiac40:Double check the green and white switch matrix wired connectors at the MPU. May have tugged on them swapping out the DMD.
Thanks, I will check that out when I get home.
Chris
Reseated ALL connections. Same issue., but I think I am on to something. I may just be dumb, but hear me out......
In the directions for the Color DMD it says:
Disconnect the 14-pin DMD ribbon cable from the CPU Board and the 8-pin high-voltage wire
harness from J2 on the Display Power Board.
J2 is where the error is. I think the game is looking for these voltages and since that is disconnected the error flags.
The directions also state:
Remove the original display, DMD ribbon cable, and high voltage wire harness from the game.
All I need to do is find the other end of wherever the connector from J2 goes in the backbox.
Time to dig.
Chris
Quoted from SilverUnicorn:Reseated ALL connections. Same issue
BUT have you tested all the switches? Nothing in that statement suggests you did.
My Display Power Board is completely out of my machine for 2 years now. My power harness is still in my machine since I need it to test out Display Power Boards or DMDs when I do repairs.
Either this error is a problem talking between the MPU and driver or there is a switch error. I haven't seen this error enough to be sure, but I really think it might be related to the big wide ribbon cable between the 2 boards.
Quoted from PinballManiac40:BUT have you tested all the switches? Nothing in that statement suggests you did.
Sorry, yes, all switches seem to work properly. The entire game works fine after the error messages disappear.
I did find this, and will dig some more once I get home again:
http://pfutz.us/Capcom/bulletin/j2_missing_zero_x.htm
Anyone else that has installed the color DMD, can you see maybe where I went wrong? Is there another connection other than the J2 on the DMD board that I missed?
Chris
This page was printed from https://pinside.com/pinball/forum/topic/pinball-magic-club/page/31 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
