(Topic ID: 162222)
Pinball machines in hot garages?
By KornFreak28
  • 203 posts
  • 48 Pinsiders participating
  • Latest reply 3 years ago by patrickvc
  • Topic is favorited by 7 Pinsiders
    There have been 11 images uploaded to this topic. (View topic image gallery).
    There are 203 posts in this topic. You are on page 5 of 5.
    #201 3 years ago
    Heh ... "separate the garage from the house so exhaust emissions don't get inside" ...
    My garage is *in my basement* ... there is no way to separate it from the house ... it's already inside!
    (shrug)
    #202 3 years ago
    I have a portable A/C unit in both of my un-connected garages. They are the type that are on wheels and have the big plastic hose that vents outside through a partially open window. I have fully insulated (but only R13) garages (24x32 and 28x32) and they can drop the temperature 10-15 degrees. Enough to keep you from sweating while standing still. I also have another two in the house (all different manuf, and sizes 10K to 16K BTU). None require water to be drained during cooling mode. In fact, the ones that just cool, don't even have a tub to collect water - it blows out with the hot exhaust air (like a window unit). But they are undersized for my application - check the specs before purchase. My 16K BTU unit is closest - 21x30 rooms by spec.
    I have only had my pinballs in the garage for about 9 months. No problems yet. But I have had a TVs, computers, and a vintage arcade in there 20 years without issue. I don't put daily drivers in the garages. No wet cars and do not open the big doors in the winter - this keeps the moisture pretty constant. The concrete floor helps slow temperature swings as well. I use a couple of $20 ceramic heaters in the winter while I'm out there (which is a lot). Min/Max temps I have seen in the garage (winter through summer) is 36 to 90F while the outside swings -12 to 100F. Much tighter when I'm out there with the heater or air conditioner on (60-85F)
    #203 3 years ago
    Quoted from jgentry:
    If you plan to keep a few pins in your garage then do it right and get a mini split. They are extremely energy efficient and while not cheap they are durable and work extremely well. For the cost of a C level B/W pin you can have your garage at perfect temp and humidity. No one wants to play pinball or work in a garage that is hot and humid or really cold. I have a Samsung mini split and love it. Costs practically nothing to run a month and does a great job.
    The portable units on wheels are crap in my experience, they are not durable and do not last. If you need to go cheap a window unit is a much better choice.
    I am an HVAC contractor and this is the best plan. I would also check if your attic above has insulation because most don't. That will make a difference in efficiency also an insulated door. I put my game room in my garage. I installed a 2 ton unit, insulated the attic space and added foam insulation to the inside of the door. Hottest it gets in there with nothing on all day is about 90 or so. I've been running it this way for 6 months
    $ 369.00
    $ 17.00
    Yorktown Parts and Equip
    Pinball Photos
    $ 27.99
    3D MODS
    $ 76.95
    $ 74.00
    Id Rather Play Pinball
    $ 99.99
    $ 4.00
    Z-connector (24 pin) Out of stock
    Professor Pinball
    $ 1,099.00
    $ 27.99
    $ 46.99
    Lee's Parts
    $ 160.00
    $ 22.00
    Full Tilt Pinball LEDs
    $ 15.45
    KAHR.US Circuits
    $ 154.00
    $ 27.95
