Pinball life page will not load on my PC, anyone else having trouble? My internet is fine, everything else is loading normal.
Quoted from Lovef2k:Pinball life page will not load on my PC, anyone else having trouble? My internet is fine, everything else is loading normal.
Works for me.
Quoted from danisme:Okay I have probably an idiotic question for you lawn gurus. I mow roughly a 30x20 lawn for my mom. Is it more efficient to just go around the rectangle as it gets smaller each time or would it be better to just go in one row at a time across? I'm terrible at spatial stuff and it's been bugging me if I could be more efficient. Now it's 100+ here so I'd like to get it done as fast as possible. Maybe it doesn't even mater.
Sorry wrong thread. Opps
I depends on how you take care of the lawn. If you care about appearance or the health of the grass. I only cut late in the day to reduce stress on the grass and it's cooler outside. If you are mulching, it doesn't matter which direction you cut. So starting on the outer edge as you described is very efficient since you are only making a quarter of a turn as opposed to a 180 degree turn around. If the mower has a side grass chute, you are throwing clippings to the uncut area and they are getting recut as you go which is good for the lawn.
Pinballlife.com just loaded OK for me.
I cut the front in strips because it looks better, but the back concentrically due to irregular shape.
Quoted from Lovef2k:I answered you anyway lol
Thanks appreciate it! I do mulch it and try to go either early or late cuz it's cooler. I posted in the lawn thread so I didn't mean to clutter up this one.
Quoted from metallik:Pinballlife.com just loaded OK for me.
I just tried again. no dice. It must be in my settings, flash player or something. I only get a partial load, no header, no menu and partial pics.
Open the Developer Tools in Chrome, on the Network tab check the ‘No cache’ option and reload. Note if there are any errors.
Also try in incognito mode in case you have a bad cookie.
Quoted from dr_nybble:Open the Developer Tools in Chrome, on the Network tab check the ‘No cache’ option and reload. Note if there are any errors.
Checking no cache didn't work but incognito did, so I should clear cookies?
Quoted from dr_nybble:Probably; could be some old cookie value causing problems.
Cleared cookies, no change.
Click this:
If you're missing an L in the address, it will bring you somewhere else, and if you have an ad blocker, that site will appear to be blank.
Quoted from ForceFlow:Click this:
https://www.pinballlife.com/
I clicked the link, but it takes me to a pinball parts source, not lawncare service. I’ll send Terry an email.
I suggest disabling your extensions one by one and trying to load the page in your non-incognito window. At least the ones that aren't enabled in incognito.
It's been a few hours since I cleared my cookies, your link worked and also manually entering the site worked as well. I was entering the correct site from the beginning so maybe it just took a while for the cookies to clear. Thanks!
This page was printed from https://pinside.com/pinball/forum/topic/pinball-life-web-page-not-loading and we tried optimising it for printing. Some page elements may have been deliberately hidden.
