I bought a Pinball Life classic stern rebuild kit, with 2 classic stern flipper bats (version 1). The Flipper shaft barely fit into the pawl on the rebuild kit on one of the flippers, the other flipper I had to hammer the actual bat in (without any set screws installed). At first I thought this was nice because it makes it a lot easier to adjust the angle of the flippers, however the 2nd flipper now is binding (won't return to rest). I wanted to see if I could grind down the shaft a bit, but now I can't even get the flipper shaft out! I have placed a philipps screwdriver underneath the playfield, through the pawl, hammering it to push it through the top of the playfield, and got it part way out, but it's hung up on something. Once again, this is with no set screws installed. The bottom part of the shaft, is too big to fit through the pawl.
Were these the correct parts to fit with each other?
Classic Stern Shoe and Shaft Flipper Bat Assembly - 02/77- 03/1980 (Type 1) SKU: 1A-284_C-611-5
("https://www.pinballlife.com/classic-stern-shoe-and-shaft-flipper-bat-assembly-1977-1980.html")
Classic Stern Flipper Rebuild Kit - 02/1977-11/1981 SKU: stn_flip_rebuild
("https://www.pinballlife.com/classic-stern-flipper-rebuild-kit-left-and-right-flippers.html")
-Pat
