I had 4 of these on order for a Seawitch Restoration I am about to start.
https://www.pinballlife.com/full-flipper-assembly-for-classic-stern-machines-031980-to-021982.html
I have seen some complaints in other threads that there are issues with binding both in the mech below the PF as well as the flipper bat rubbing on the upper side of the PF. Before I saw those threads this was a total no brainer. 52.95 for the whole assembly that includes the bushing and coil vs. 54.95 for a rebuild kit that does not. In my case the coils are all mismatched so it made even more sense. i have two questions
Have you run into these issues?
Do you know if these complete mechs are using the same exact parts from the rebuild kits? I have used those plenty and they are great. If they are the same I will just part out these new mechs and use the old base plates.
