I'm a true fan of LED's. I've put them in every game I've owned and I think its a fun and creative way to personalize your game. The problem I'm having is no one makes a good GI bulb. If you look at the retailer websites (cointaker, cometpb etc) they recommend the biggest brightest bulbs for GI. Generally smaller bulbs are discouraged for GI use because they create hot spots and don't throw enough light to the sides. The problem is the super bright bulbs end up looking like this.
https://forum-s3.pinside.com/201311/1218577/148515-i.jpg
The bulb is giving out an impressive, perhaps to impressive, amount of light to the sides which is exactly what I want in a GI bulb. Its also giving out the same amount of light directly behind the plastic creating a hot spot. Actually, the whole plastic is a hot spot!
So my question to LED bulb manufacturers, is it possible to make a GI bulb that creates lower intensity diffused light directly above the bulb while throwing out enough light to the sides to illuminate a game placed in low ambient lighting conditions? To me this would be the perfect GI LED bulb since you would not blow out the playfield plastic artwork or your cornea's in the process.
My question to modder's and LED lovers, has anyone taken something as bright as the optix maximus bulbs and sanded or painted the bulb to achieve the same effect described above?
