Pinball Horror Pics!!
(Topic ID: 126494)
By Star_Gazer
  • 1,754 posts
  • 400 Pinsiders participating
  • Latest reply 2 days ago by jorro
  • Topic is favorited by 202 Pinsiders
There have been 905 images uploaded to this topic. (View topic image gallery).
There are 1754 posts in this topic. You are on page 35 of 36.
#1701 20 days ago
Quoted from someotherguy:
This one was locking on all the coils upon boot up due to the MPU issue; and yes, without doubt someone had either severely over-fused it or had shorted the fuse clip to "fix" it. No other way it could have burnt those coils like that. One thing that was interesting is I could boot it with the solenoid fuse out, then install it after it booted, and play a game. Next power cycle, *pow* there goes the fuse.. game like that is where using the light bulb rig in place of the fuse helped save a lot of frustration. Keep working at it until the light bulb doesn't come on anymore; no more wasted fuses..
Sounds like an issue with the blanking circuit. I had the same problem intermittently for years on my BK, and the solution wound up being the 555 timer, a tantalum cap, and a transistor (all in the blanking circuit region of the mpu) that needed to be replaced to fix it. Basically the blanking signal was going high as soon as the game was booting, causing all the coils to lock on upon boot-up. In my case it was blowing the 2.5a solenoid fuse due to the coils locking on. I also found i could replace the fuse after the game booted and it would work fine for hours. Weird problem.
#1702 20 days ago
Quoted from frunch:
Both of y’all have mentioned replacing a fuse after booting, and I’ve never tried it yet alone thought about it. That’s odd that games work like that. Does the fuse not blow after a few minutes of replacing after a successful boot?
As for blanking issues, so many times are they fixed by that tantalum capacitor. Anytime I’ve got a blanking issue, that’s the first thing I do and most of the time, the problem is resolved. This is especially true for Sys11 games with alkaline damage that leads to blanking issues.
#1703 20 days ago
I don't recall if I have posted this before, but here is a picture of the worst playfield that I have come across. It took me about a year to find a replacement playfield for it. This one got donated to CPR for their High Speed playfield project. I guess they used it to pull off measurements for the CNC stuff.
#1704 20 days ago
Quoted from scasey:
[quoted image][quoted image]
I’m not surprised a High Speed looked like that. They made a shit ton of money back in the day. I was a kid, but I think dad had 4 or 5 of them on route. It was definitely one of the best earning games ever built!
#1705 20 days ago
Quoted from frunch:
Yes; I had mentioned the blanking in the original reply #1690. It's been many years but if I recall it was just the 555 timer that was bad on mine.
Quoted from cottonm4:
Can you share this light bulb trick? Do you wire a light bulb to a broken fuse? What kind of light bulb?
Thank you.
I use a 100W bulb in a base with terminals on it so it can be easily attached using alligator clip leads. Use it in place of the fuse. It can eat up enough current that it will glow dimly when there's a short, and can be left on like that without damaging anything. I personally find this more useful than a circuit breaker that will trip, but to each their own. With the light bulb as a diagnostic tool, you get an instant and continuous indicator of a problem, and you don't have to do anything with the tool - just keep working at what the problem may be. Not a huge difference from running a circuit breaker, but I believe helpful. Attached pic - bulb hooked to solenoid fuse with a dead short on that circuit.
Richard
#1706 20 days ago
#1707 20 days ago
Quoted from ryanbrooks:
We have a 3A circuit breaker that has a blown fuse soldered to it so it inserts into a fuse holder. We simply push it and reset it.
In re light bulb, look at this:
https://www.repairfaq.org/samnew/tvfaq/tvtslbt.htm
People have done it for years on power amps. I have a Sencore variable isolation transformer that works well also.
Thank you. I'll study this light bulb business.
I have a collection of thermal circuit breakers in my collection. I have 3/4 amp all the way up to 30 amp. Finding ones below 5 amps is a challenge and they are not cheap cost wise. I have had three go bad.
11
#1708 18 days ago
A few pictures from a recent trip to Africa!
#1709 18 days ago
There is a fathom in there! Depressing.
#1710 18 days ago
Quoted from matt_adams:
You posted that last year too, but at the time couldn't say where it was cause of an impending deal, but now you say Africa...so does that mean the deal was either done or won't be? Please elaborate if you can...thanks!
#1711 18 days ago
#1712 18 days ago
Quoted from Stoomer:
Sorry, I hadn't realised I had done that! I have to say the deal has not been done yet mainly to the instability of the region, hopefully it will happen. Hers is a photo of some of the machines we are trying to save to give you an idea why we are being a bit cagey about it!
#1713 18 days ago
Wow...thanks for the update...I wish you luck!!
#1714 18 days ago
Hmmm that fathom and that trek...
Send them over here
#1715 18 days ago
I am not sensitive to down votes. It is part of the game. But why was my post voted down for saying "Thank you"? This one I do not get.
#1716 18 days ago
Perhaps it was an errant click? I know i've accidently downvoted something once. I noticed and reverted it when I did it. I don't see any downvotes now.
#1717 11 days ago
If people view Pinside on a tablet and scroll up and down on the right side it is easy to accidentally up vote or down vote a post without even realizing it.
#1718 11 days ago
Quoted from Robotworkshop:
Exactly what happen to me. I removed my down vote on your 2nd post. Must of clicked there by mistake scrolling through the posts.
#1719 10 days ago
Quoted from Colsond3:
I’d buy that Mephisto glass too!! Ask him if he wants to sell it? I’ll pay you a finders fee and to package it up!
I've finally talked to the owner. The backglasses will stay there forever: there is wall just behind this windows. No access from the inside.
#1720 10 days ago
mmmmm 5 volts not working ...idea-see photos .anyone recognise their work
IMG_0629 (resized).JPGIMG_0631 (resized).JPGIMG_0632 (resized).JPGIMG_0633 (resized).JPG
#1721 10 days ago
Fixed exactly the same GI hack before two weeks for a friend.
Looks like this one is very popular.
#1722 10 days ago
Quoted from arakissun:
came from Lisbon , Portugal , I think . where are you? country
#1723 10 days ago
Quoted from trumpy:
I had the same install, power supply same spot, power tap same spot. It was a UK reimport.
#1724 10 days ago
I'm from Varna,Bulgaria.
#1725 10 days ago
Quoted from roar:
And an HH, Xenon, Spectrum and a damn Spirit. All great games. Man, that is depressing.
#1726 10 days ago
Quoted from Vincenzo:
Damn that sucks. What a waste. All hope is not lost. Tell him I’ll be over with a jackhammer...or maybe a rock hammer.
#1727 9 days ago
What are the big round metal disks? They seem to be removed from the picture above it. Giant Pop Bumper caps? Used for tables or...?
#1728 9 days ago
Nice Bally coin door on the left.
#1730 9 days ago
I was hoping they are UFO's
#1731 9 days ago
I'm imaging an awesome topper for AFM.
#1732 8 days ago
Belt pulleys to drive a turn-table? Aka Jukebox parts.
#1733 7 days ago
Quoted from dementedwarlok:
Weird way to park must be drunk aliens!
#1734 5 days ago
20190314_185337 (resized).jpg20190314_185342 (resized).jpg20190314_185344 (resized).jpg
#1735 5 days ago
Quoted from Mitch:
That will buff right out.
#1736 5 days ago
Quoted from Mitch:
Fixed worse.
#1737 5 days ago
Quoted from Mitch:
Why on earth...
Just the front panel??? I don’t understand the reasoning?! I’d tried kicking one out before when I had to rebuild a rotten cabinet, and also for a cabinet that exploded.
Both times those panels were really damn hard to separate from the sides. I mean full body weight would not break them. Took pry bars and half an hour of working it over to break them off!!
#1738 4 days ago
Quoted from Isochronic_Frost:
Why on earth...
Hard to say what happened to it in the past. I bought a Fire! project years ago that was sitting legless on some battered commercial carpet. Needed to pull it away from the wall to stand it up, and with no legs I couldn't grab it from underneath, so I opened the coin door and pulled on the inside of either side. It refused to budge on the carpet, and the front plate came completely off the cabinet.
The cabinet showed no signs of water damage but was pretty beat up all around. I had to shore up the backbox as well. Lots of wood glue and bar clamp action later, and the cabinet was solid again.
Richard
#1739 4 days ago
Do not let these guys transport your next game
#1740 4 days ago
Quoted from Bundy:
At least the one that is most coveted is on top....
#1741 4 days ago
Quoted from hollywood:
lol ... but what game is that under the LW3 ? EDIT: never mind Popeye
#1742 4 days ago
#1743 4 days ago
Quoted from dudah:
yeah , but were your flipper bushes screwed to the playfield with security head self tapper screws like I just found mine
#1744 4 days ago
Quoted from JodyG:
Sick burn.
#1745 3 days ago
Speaking of screws...
#1746 3 days ago
Quoted from hazmat7719:
Think I buffed to hard.
20190316_192928 (resized).jpg20190316_193100 (resized).jpg20190316_194044 (resized).jpg
#1747 3 days ago
Quoted from the_zap:
Man...right through the playfield. I never understood that..people do realize that screws come in different lengths right?
#1748 3 days ago
Quoted from Mitch:
I have had to get rid of a few cabinets that were just too far gone as well. I wish that I had the time to make stencils of the artwork before they went to the dump.
#1749 3 days ago
I've recently started to scan my games as they come in, just in case.
#1750 3 days ago
I actually used the sides of a rotten cab as wall art, looks kinda cool if you clean it up decently. Seal it and nail it up, now you can have even more pinball machines, on your walls!
$ 55.00
Pinball Photos
Metal-Mods
Bright Lights Pinball
$ 229.99
PinballBulbs
$ 41.00
$ 22.00
Yorktown Parts and Equip
York, PA
$ 3.00
Doc's Pinball Shop
Trade
Machine - For Trade
Corpus Christi, TX
Metal-Mods
Utica, MI
$ 175.00
Professor Pinball
Third Coast Pinball
$ 72.95
$ 16.50
€ 15.00
FLIPPROJETS
$ 104.00
Sparky Pinball
$ 7.65
Cabinet Parts
Third Coast Pinball
Third Coast Pinball
2,400 (OBO)
Thousand Oaks, CA
