(Topic ID: 306722)
Pinball Electrical Connector Sources
By greatwichjohn
2 years ago
  • 23 posts
  • 12 Pinsiders participating
  • Latest reply 2 years ago by G-P-E
#1 2 years ago
Looking to see if a list of sources can be gathered here to help out those building their own wiring harness. My first project is Bally Medusa main head trunk wiring harness. So looking for all the unique size .100 & .156 header pins & connectors. The male & female harness + contacts used.
.100 size connectors - 12, 15, 16, 17, 19, 23, 25, 28
PBR: 12 Position MOL-2201-3127 $0.72
Marco: 15 https://www.marcospecialties.com/pinball-parts/CF10015
Marco: 23 https://www.marcospecialties.com/pinball-parts/CF10023
PBR: 28 Position Terminal Housing. BLY-E764-28. $1.50ea.
.156 size connectors - 2, 8, 9, 10, 15, 18, 20
PL: 2 https://www.pinballlife.com/156-396mm-crimp-stuff-2-position-housing-with-locking-ramp-17574.html
PL: 8 https://www.pinballlife.com/mm5/merchant.mvc?Screen=PROD&Product_Code=PBL-600-0332-00
PL: 9 https://www.pinballlife.com/156-396mm-crimp-stuff-9-position-housing-with-locking-ramp-17443.html
PL: 10 https://www.pinballlife.com/mm5/merchant.mvc?Screen=PROD&Product_Code=PBL-600-0334-00
PL: 15 https://www.pinballlife.com/156-396mm-crimp-stuff-15-position-housing-with-locking-ramp-17577.html
PL: 20 https://www.pinballlife.com/mm5/merchant.mvc?Screen=PROD&Product_Code=PBL-600-0344-00
Rectangle size housings? 12, 15, 24
One of my limited sources: https://www.mode-elec.com/
#2 2 years ago
Great Plains Electronics is as great source. Not sure if he has all of what you need though.
#3 2 years ago
I read a vid1900 post that said to replace .100 pins with .156 pins on old Bally and Stern boards as the .100 are unreliable.
I buy from Great Plains Electronics G-P-E some people buy from Digikey or Mouser.
#4 2 years ago
Pinball Life, Marco Specialties, Pinball Resource, etc. Looking for the unique size or hard to find stuff. If you see that specific source with part, please post it up here to help others. Here is a unique Gottlieb one I located:
https://www.peawo.com/Molex/09-01-6241--92734818.html
#5 2 years ago
You can search in this area on the Pinball Life website for the connectors that you might need:
https://www.pinballlife.com/molex-crimp-stuff-connectors-and-parts.html
#6 2 years ago
I'd start with digikey, since they're Canadian and can ship to you cheaply overnight
Then GPE, since this is Ed's specialty.
Then the usual suspects for all parts pinball.
#7 2 years ago
Big Daddy has a lot of the Bally stuff, but some of their connectors have to be trimmed to fit. You just can’t find some of this stuff anymore.
https://www.bigdaddy-enterprises.com/
#8 2 years ago
Thanks guys looking for other suppliers that are not well known in the pinball biz. There are unique sizes that I need for production, & others looking for the same. I will start listing my preference at the top to make it easier for people to get the info.
#9 2 years ago
Quoted from greatwichjohn:
I’m happy to test the Medusa head harness once it’s ready!
#10 2 years ago
All of these can be found here --
Genuine Molex (larger sizes no longer available) --
https://www.greatplainselectronics.com/products.asp?cat=68
Generics (all sizes available Including the elusive 25 and 28 pin plugs.) --
https://www.greatplainselectronics.com/products.asp?cat=164
https://www.greatplainselectronics.com/products.asp?cat=86
Generics (all sizes available) --
https://www.greatplainselectronics.com/products.asp?cat=81
Those 24 pin edge connectors -- had several thousand but now completely sold out for me.
We still do have a few other sizes of Molex edge connectors for Gottliebs --
https://www.greatplainselectronics.com/products.asp?cat=77
And AMP edge connectors --
https://www.greatplainselectronics.com/products.asp?cat=128
#11 2 years ago
Thanks I was just going to start linking up GPE stuff also. Another item looking for is 20 position IDC female housings for the displays.
#12 2 years ago
Quoted from chad:
I've usually found Great Plains the goto place for connectors.
#13 2 years ago
Quoted from bluespin:
I think you misunderstood what vid1900 said. .100 and ,156 are 2 different sizes and are not compatible with each other.
Can you post a link to where he said that? You have me very curious now.
#14 2 years ago
.156 male pins don’t fit in .100 holes on the circuit board.
Always repin .100 header & female connectors.
Only if you have the soldering and crimping skills
I have seen a lot of bad crimps when going through games
#15 2 years ago
Yes I always tell people to only do contacts for harness that need work. Do not do everything! As for .062 Molex style plugs seems like these are very hard to find stocked anywhere. I need 15 + 24 female for the Medusa harness.
#16 2 years ago
Here is a source for Red 20 IDC housing. Looking for a source of the covers.
https://www.mouser.ca/ProductDetail/TE-Connectivity-AMP/5-640440-0?qs=xz7l0OwElPUCXhRQfQ2a5g%3D%3D
Things are moving very slowly for Medusa Head trunk harness since the parts are so hard to source out.
Lots of Red 15 IDC available. Here is one model with locking tab.
https://www.mouser.ca/ProductDetail/TE-Connectivity-AMP/4-643813-5?qs=TwthSIU6nQz4DRmuOejuaQ%3D%3D
#17 2 years ago
I just heard about Great Planes Electronics and I spent 6 hours comparing different suppliers but they have the best combination of parts and prices.
I haven't bought from them yet being that I just heard of them about a week or so ago, but I have a couple hundred dollars worth of parts I need to order. I keep refreshing my cart but their store is still closed so I rush ordered parts from Marco for a customer machine so Marco is also a good alternative.
#18 2 years ago
Yes I am still on the hunt. GPE is out of stock on what I really need.
#19 2 years ago
You can also get some Molex 0.156 and 0.100 connectors and pins from Pinball Life.
See attached link for the 0.156 page.
https://www.pinballlife.com/molex-156-idc-connectors-and-parts.html
#20 2 years ago
Which one are you looking for?
#21 2 years ago
It would be nice if a Gottlieb system 1 ,system 80 kit could be offered to replace all of the connectors.
#22 2 years ago
.062 receptacles 15 & 24, possibly plugs also. I asked you previously & got no response to a pm. Anything over 12 seems impossible to find stocked anywhere in the world.
#23 2 years ago
Oh yeah, those 15 and 24 pin 0.062" connectors. I ran out quickly of these two after the last time buy. I found another source for the 15s which were supposed to be identical to Molex connectors and be able to use real Molex contacts. Well... they weren't identical. Now I have two cases of plastic sitting under my Stern Big Game. Useless but too expensive to through away.
Still looking, though.
Regarding Gottlieb System 1 or System 80 connector kits. Doubt that will happen, those obsolete connectors are disappearing fast.
$ 69.00
Playfield - Plastics
Pinball Shark
$ 18.95
$ 139.00
Pinball Pimp
$ 69.00
Pinball Pimp
$ 22.95
£ 195.00
West Point, UT
$ 149.95
Allteksystems
This page was printed from https://pinside.com/pinball/forum/topic/pinball-electrical-connector-sources and we tried optimising it for printing. Some page elements may have been deliberately hidden.
