(Topic ID: 36295)
Pinball-centric tools?
By lukerp
11 years ago
  • 26 posts
  • 17 Pinsiders participating
  • Latest reply 11 years ago by billycrna
    #1 11 years ago
    Hey all,
    Not sure how this popped into my head, but I was curious as to what people have for pinball specific tools? In other words, things that are either only for pinball, or that you purchased more or less just for pinball? I have:
    - two tumblers; one blew the motor, so I ended up with a second, and will eventually replace the motor on the first
    - two DMMs
    - various sockets, Allen keys, etcetera
    - fuse and chip pullers
    - crimper for doing Trifurcon connectors
    - ultrasonic machine
    - motorcycle jack to be converted town all dolly
    - soldering iron
    - soldering station
    - likely going to grab a bench grinder for polishing parts sooner or later
    - there is a random orbital polisher that should be delivered tomorrow, along with polishing wheels and compounds (according to the tracking info, it's in the city, so I'm guessing it'll come tomorrow); that'll be for doing playfields
    Anyone else have enough tied up in machinery to buy another game? This is also me fishing for other tools I might "need"...
    Luke
    #2 11 years ago
    Every tool I have ever bought has been for pinball. With the exception of metric sockets for video games from Tokyo.
    If you need a tool, there is no substitute. Trying to get by or make something work only makes the job harder and more costly.
    #3 11 years ago
    Do you have the long nut drivers?
    #4 11 years ago
    Hey,
    I actually don't. The guy who left his 1/4 and 5/16 drivers in my TZ wasn't kind enough to give me the others, but definitely something I'll keep in mind.
    Luke
    #5 11 years ago
    Klein magnetic nut drivers are the only way to drive your nuts. (Comments invited.)
    #6 11 years ago
    Custom grit gitter, every pinhead that sees this grabs it and I have to make another one.
    #7 11 years ago
    Leaf adjustment tool
    Magnetic nut drivers
    Electronic Level
    Forceps
    Molex Pin Crimper
    Logic probe.
    Bulb extractor
    Bulb socket cleaning stick
    Bunch of circuit board tools like chip pullers and scrapers and stuff.
    Torx Security bits and those square ones.
    #8 11 years ago
    Quoted from tracelifter:
    Custom grit gitter
    I give up. What's it made from, and what does it do?
    #9 11 years ago
    Gonna take a guess..
    Looks to be a flexible steel core with a hook at the end.
    Soft rubber hose allows to be compressed and expose the hook which grabs an object.
    The rubber cup at the end of the hose helps to "git" the "grit".
    Wood handle is just for flair.
    That all said, I'm wondering the advantage over a regular old pick-up tool.
    http://www.northerntool.com/shop/tools/product_200382240_200382240?cm_mmc=Google-pla-_-Garage%20%2B%20Workshop%20Supplies-_-Magnets-_-254933&ci_sku=254933&ci_gpa=pla&ci_kw={keyword}&gclid=CIbBx7z357QCFeZDMgodxWkAcA
    faz
    #10 11 years ago
    Quoted from RCA1:
    It is made from a hardened steel BBQ skewer and a surgical rubber hose with a molded end.
    You put a small rag on the hook and the rubber end covers it.
    Novus 2 on the rag and you can push it up to get to the ball tracks in orbits under ramps etc.
    Unlike the grabber pictured it is shielded so you don't scratch anything and you can put pressure downward to remove ball tracks and the magic dust.
    Makes it easy to keep the games clean between shop jobs to get into tight areas without removing ramps.
    #11 11 years ago
    Nice! The coin on the end of your device in the photo led me astray.
    #12 11 years ago
    telescoping rod with magnet on the end. magnetic bowl for holding screws, multi led light with magnet and hanging hook for working under playfield, all avilable at harbor frieght.
    #13 11 years ago
    Picked up this nifty gadget today for $4 at harbor freight. Works like a charm!
    Note to self: new flipper rubbers for SBM...
    #14 11 years ago
    Come on man, that flipper rubber is disgraceful.
    #15 11 years ago
    Quoted from Wolfmarsh:
    The one on the right is riding too high on the end, too.
    #16 11 years ago
    This looks like a contraption made from parts off my anesthesia cart! LOL
    #17 11 years ago
    Also,if you were selling them...I would buy one!
    #18 11 years ago
    Quoted from billycrna:
    It is a hose off of a Gompco suction machine, I made a solder sucker out of it for board work.
    I have more hose but I swiped the skewers from the wife and I am out of them or I would send you one.
    #19 11 years ago
    Nut drivers: magnetic, hollow shaft, long and short shaft variants in 1/4, 5/16, 11/32, 3/8. #1 most important thing to have. Use them all the time.
    Long shaft sockets. Less dicking around with open end wrenches ... except:
    1/4" thin open end wrench. When you go to remove nuts securing plastics and the post below starts coming out of the pf you'll be happy you have this.
    Leaf adjustment tool. Keep your fingers and pliers away and do it right.
    Penny tech: save any soft foam packing material. Cut up and use to apply polish/Novus2
    Good glass cleaner (Stoner Invisible Glass) and a case of paper towels. Nothing worse than a fine pin collection that looks like someone rubbed down with a baloney sandwich.
    #20 11 years ago
    Thank you for the thought! It's ingenious!!! Would work perfectly on my Tron. As of yet, I have been unable to clean under the back ramps. I'm too lazy to take them off....so far.
    #21 11 years ago
    home depot paint mixing stick and micro fiber cloth.
    #22 11 years ago
    Amazon sells a box of microfiber towels for less than a buck a piece. Feel that's a must for safe cleaning. Not a huge fan of washing and re-using those towels so I usually use one or two and then throw them out or relegate them to garage duty.
    http://www.amazon.com/Zwipes-Microfiber-Cleaning-Cloths-36-Pack/dp/B000XECJES/ref=sr_1_2
    #23 11 years ago
    Wal-mart has a pretty good price on them but I spend a little more and get them in bags of 20 at O'Reillys auto parts. I like them because they come with several colors in the bag. The Walmart ones are all the same colors.
    #24 11 years ago
    Wow, most people just have a beer fridge or at best maybe a bar in their game rooms! You have an anesthesia cart? I want one!!!
    #25 11 years ago
    #26 11 years ago
    Quoted from BadBrick:
    LOL!! Those would be interesting parties at my house if that were the case! I meant at work
    This page was printed from https://pinside.com/pinball/forum/topic/pinball-centric-tools and we tried optimising it for printing. Some page elements may have been deliberately hidden.
