(Topic ID: 284032)
"Morning MU/TH/UR" Pinball Brothers Alien Remake Owners Club
By Red_Devils
1 year ago
  • 5,259 posts
  • 299 Pinsiders participating
  • Latest reply 1 hour ago by McDoom
  • Topic is favorited by 150 Pinsiders
Topic poll
“What are you in on an SE or LV?”
  • LV 62 votes
    33%
  • SE 59 votes
    32%
  • Not interested in this game 65 votes
    35%
(186 votes)
This poll has been closed.
There are 5,259 posts in this topic. You are on page 48 of 106.
#2351 4 months ago
Quoted from Mageek:
I had the same problem so I 3D printed this thing to help keep the ball from bouncing back into the trough. Original is on the right
[quoted image][quoted image]
I love this fix. Nicely done and thanks for sharing.
#2353 4 months ago
Quoted from brado426:
Do you know that you have the Gen. 2 Xeno targets and not Gen. 1? I have Gen. 1 and Cato is sending me Gen. 2 targets. I highly suspect my Xeno grab problems is because every time the ball hits the Xeno targets, it hops right over the magnet. Curious if the same thing is happening to you. I'm on 2.2E and IF the ball doesn't hop over the magnet, it looks to me like it would be pretty reliable.
Edit I figured it out
#2354 4 months ago
I see it happen at least once or twice in 10 games. Has anyone else seen this problem, so I can tell Cato whether or not it is just me?
I have seen this as well. Has to be code.
#2355 4 months ago
This, 100%. If the ball doesn’t bounce on impact the ball is grabbed damn near every time. I have gen 2 coming as well.
#2356 4 months ago
Quoted from dri:
I do not enjoy playing this game in the dark at all. Most inserts are flashing annoyingly bright and fast which makes the PF incredibly hard to see. I don't know if you can adjust the pulse and brightness of the inserts to get a more smooth dark experience. I only stream this game at the moment, with the overhead lights it looks and feels great IMHO. My comparison is Stranger Things where I have inserts dialed down as low as I can and it gives you a much better moody game in the dark and UV effect gives you true dialed to 11 effect (no pun intended).
There is a led brightness setting in the adjustments
#2357 4 months ago
Your sticky flipper issue is easily solved by following these instructions:
I had made this a Key Post a while back, right now we have 2 key posts both by HurryUpPinball If anyone else has suggestions for key posts let me know.
#2358 4 months ago
This is probably a stupid question, but what does the stand up target in between the Sleeper ramp and drop ramp that says "recharge" do?
#2359 4 months ago
It does various helpful things during modes and multiballs. Can spot lit shots, increase shot values, stuff like that.
#2360 4 months ago
Fixed my ball bouncing back into the trough occasionally issue. And put the ball in the trough super quiet now. I guess that metal protection on the rail makes the ball shoot back into trough and lots of noise from it.
Loads like silk now.
#2361 4 months ago
Quoted from kciaccio:
Loads like silk now. [quoted image][quoted image]
Hmmm... could it be that simple? I'll try something like that and see if it helps.
#2362 4 months ago
And the coil is backed down to minus 40.
#2363 4 months ago
Well, Well, Well.....
I added this adhesive piece of auto detailing trim and not only does it look like it was meant to be there, but my ball ejects have been flawless for 5 or 6 games tonight. I'm cautiously optimistic, because I've thought this was fixed before and then the intermittent behavior started again. Thank you... this may be the ticket!
#2364 4 months ago
Exactly the same behaviour like at the HW-ALIEN, if a metal sheet for the wood rail is mounted.
Remove it and you have no more issues in that case.
You will get more problems if Cliffy's for the shooter lane are installed.
In combination with the wood rail protector it's nearly unplayable.
Once a ball will reflect into the trough, the CPU will increase coil power in the same way as at the airlock scoop, so it's getting worse.
My recommendations is to decrease coil power for the ball trough, as I said the CPU will increase the coil power automatically if a ball is reflected.
#2365 4 months ago
Quoted from Averell:
Interesting. It did feel like this game changes on the fly with these coils.
#2366 4 months ago
Even to keep the facehuggers alive, coil power should be reduced to the maximum... Egg-Bumpers as well.
"Egg destroyed" can happen really and it's not funny to repair these damend Data/East-Assies.
#2367 4 months ago
Good to know. My Egg pops rock. They should probably be turned down.
#2368 4 months ago
Looks like Cointaker is done selling the standards? Not on the site anymore. Tried emailing with no response but I'm assuming it's because of labor day weekend. I was just getting ready to order and the price increase hit and they are not listed on the site now, bummer, looks like I missed out. Maybe they are getting ready to start building the Limited Version and be done with the standards for awhile?
#2369 4 months ago
Quoted from pcprogrammer:
standard is still there : https://cointaker.com/products/httpscointakercomproductsalien-standard-edition-by-pinball-brothers
#2371 4 months ago
The picture says "1st Quarter 2021 - Sold Out"
Yeah, they're into the 3rd and 4th quarter deliveries now, just looks like they haven't updated the description - still allows you to add to cart. I was told that next batch, which my game is supposed to be in, should be leaving Italy end of September/early October.
#2372 4 months ago
Quoted from Krakatoa:
Didnt realize that you could add the Q1 SV to cart even though it says sold out. When i placed order they had a selection for Q3 delivery.. seeing that removed and having PB announce the LV for Q4 got me nervous and a bit excited. Thank you.
#2373 4 months ago
I hope they make plastic protectors soon.
Already have a broken plastic behind the recharge stand up target.
#2374 4 months ago
They don't already exist? Plastics are the same as OG aren't they?
#2375 4 months ago
Already have a broken plastic behind the recharge stand up target.[quoted image]
Figured out what recharge did?
Thought some of the plastics had changed. This one looks like at least has one less drilled hole.
#2376 4 months ago
Quoted from c818919taylor:
Ferret indicated that it has various functions (eg spot lit shots, increase shot values, etc) depending upon the mode or multiball
#2377 4 months ago
I always thought that the recharge target lights up the left out lane savers? If not, how do you light those?
#2378 4 months ago
Shoot the upper (Hypersleep) ramp to light a Revive light on the left outlane.
#2379 4 months ago
Has anyone started a write-up of the modes and rules yet?
#2380 4 months ago
Averell has created an amazing rules and reference document:
https://www.ipdb.org/files/6419/2017_ALIEN_Standard_Edition_Rulesheet_Rev_1_2_dated_2020_08_05.pdf
Some details may not be quite correct for the Pinball Brothers models, but it should be close enough.
#2381 4 months ago
I have sent all my plastics off to a guy with a CNC cutter he does plastic protectors as a hobby. Will post pics when he is done with them.
#2382 4 months ago
Quoted from s000m:
Follow Hurry Ups advice on the post before this happens ..[quoted image]
Burthamburg... you were supposed to be the chosen ones!!
Played one on location last week. One of the lower flipper bats had already broken and been replaced and during my play the upper right snapped off. The flippers also lost power during gameplay more than once. I wonder if the resets and possibly the flipper power issues are related to lugs being grounded like the one dude had with his drops.
-1
#2383 4 months ago
Quoted from Chalkey:
In my honest opinion for a machine that costs this much I think these short comings with the build quality are inexcusable! Do they do any tesitng at all or really care at all
I think it's utter BS that so many new owners have forked out all this money and had these issues! Broken flippers (WTF), broken plastic parts, having to re do weak playfield parts, code issues, drop down target failures, shooting lane issues (where you have to put in a bit of soft plastic yourself), xenomorph tongue ball pickup issues, having to sand down flipper parts to get flippers to return properly, wires getting shorted on solenoids because they move around, etc, etc.
Are we paying all this money to be their field testers? Why the fk should we have to act as their quality contol? Not good enough PB!
You may argue "oh it's a new machine" and "bugs need to be sorted". Well fine, give us a discount for the lack of inhouse testing. It's not right for the end paying user to cop this lack of build/test quality. If you let the manufacturer(s) get away with this they will walk all over you.
Sometimes I think you guys are so keen for these machines that you allow the manufacturer to get away with it. Not good practice.
If you let manufactures of anything get away with this then we all pay more and get less. It's on the manufacturer to sort these things out before their product goes to market. Not us the customer!
Not happy!
#2384 4 months ago
First machine from a new manufacturer. There are going to be growing pains and so far it seems they've done a good job with support and are working through the problems. I wish I had one to help with the testing
#2385 4 months ago
Quoted from HurryUpPinball:
One thing I would recommend is to check the post directly in front of the upper right flipper. I noticed it moved a little after about a week of play so I added some loc-tite and reinstalled it. About a month or so later, I noticed it was coming loose again. There is a t-nut in the bottom of the playfield and it is located under the flipper plate mech. After digging further into it, it appears there is only a few threads that make contact with the t-nut. I grabbed a Bally Williams post, another washer, and a low profile locknut and replaced the stock PB post and t-nut. As you can see from the pic, this could get pretty bad if it is loose as the post takes a lot of direct hits. The wear from the old washer is covered by the new washer I installed but thought I would share this so others could check and adjust as need. The post I used was roughly about a 1/4 of an inch longer (the threads) but not so long as to contact the flipper plate.
Anybody knows which exact post to use there? Don't have any and I have to order it specifically, so a link or the like would be greatly appreciated.
Thank you all!
P.S.> Should that be a key post?
-3
#2386 4 months ago
I guess it's what you consider "is a good job". I think it's a crap job for the money. PB must love customers who have your attitude torwards poor build quality on release.
#2387 4 months ago
Quoted from Optimiser:
Not happy!
I got a discount. I paid 7777.00 for mine.
Seen the price to buy today?
15
#2388 4 months ago
I agree with this.
Not happy!
We knew there would be problems and I, for one, am happy to help PB work through these issues. They are obviously committed to helping resolve whatever comes up. It is not a matter of "letting the manufacturer" get away with anything... it is a matter of early adopters helping the manufacturer... and by the way, us early adopters did get a discount. As far as I'm concerned, $7777 was a reasonable discount. Like I've said before, replacing these parts is super easy and many of these issues (like broken flippers) were really beyond PB control. They need to work with their parts supplier just like anyone would to get the issue resolved at their expense. So I think the best thing to do is to be a bit grateful and realize that the alternative is no Alien pinball ever. I'm a pretty darn happy customer.
-3
#2389 4 months ago
Seen the price to buy today?[quoted image]
Absolutely not the point. That's no excuse for poor bulid quality on release.
#2390 4 months ago
If it wasn't the point, you shouldn't have brought the price up as a point.
-6
#2391 4 months ago
I agree with this.
LOL at "greatful". What for dodgy build quality for a piece of equipment that costs this much? Do PB sponsor you? Nothing reasonable about paying $7777 USD for a machine released with these build quality problems. They must love you guys who put up with this.
If they were truly "committed" they would make sure there weren't these build quality problems on release to the buying public, simple as that.
They're not helping the customer, they are helping themselves.
Instead of being so understanding and nice to PB, they should be utterly hammered about this.
-1
#2392 4 months ago
Knew you'd say that.
PB love you.
#2393 4 months ago
There's a difference between bugs in the code, issues with custom mechs, etc and stuff like the generic flipper bats, defective standups, etc they cheaped out on instead of buying proven ones from an experienced supplier. Even the board issues, as much as I give a new manufacturer some leeway on, could have been avoided if they just used an existing boardset. There isn't a shortage of existing board systems out there to choose from.
#2394 4 months ago
Quoted from zacaj:
PB is at the mercy of other manufacturers for some of these issues. The pinball bat issue, for example.... I just bought replacement bats from Pinball Life and received the EXACT SAME product from the same manufacturer that PB used. Do these bats have the same issue? I guess I'll find out... but PB is sending me replacements bats that are actually different. So I really have no concerns about broken bats.
My recommendation to anyone who is considering buying a pinball machine is don't buy one unless you can work on the machine yourself. I think people with the sour attitudes are people who aren't willing or capable of fixing problems themselves. If you're one of these people, stay out of pinball. Any friend of mine who ever bought a new pinball machine dealt with far worse issues than I've dealt with on this Alien before, so I think the sooner people just accept that it is the nature of "the beast", the happier they will be.
#2395 4 months ago
Hi All,
Not sure if this has already been asked or addressed.
Has anyone ever changed the flipper buttons out? Mine feel wobbly and loose compared to my Stern/Data East Pins.
Cheers,
Scott.
#2396 4 months ago
Quoted from s000m:
Hi All,
Cheers,
Scott.
At first I didn't like the sensitive buttons.... but now I'm used to them. Now my Williams buttons feel too stiff. There must be a happy medium somewhere.
#2397 4 months ago
I walked into this with eyes wide open. I bought and paid in full for a NIB project. I can't say I'm struggling with my decision.
#2398 4 months ago
It comes from the cabinet switch. Not the button. The stronger the cabinet switch the more stiff the button. Adjust the switch to be closer to the cabinet wall to stiffen the button feel. Or replace the cabinet switch with a stiffer one.
#2399 4 months ago
Quoted from dri:
Same here... I think the only people disappointed are those who were expecting the unreasonable.
#2400 4 months ago
Quoted from s000m:
Mine were a bit whiny caused by the friction, a dab of novus 1 and they're now smooth and responsive. I agree they're a bit flimsy but I prefer that over the Stern ones that gets stuck for the smallest speck of dust.
