Quoted from dyopp21:From the machine I received today I have a couple of issues I'm still dealing with, so figured I would share them here:
1. The left spinner switch is DOA. I removed it from the playfield to make sure it was connected. As well as from the board on the bottom of the PF. Connections were solid. No joy in switch test. Interestingly, neither spinner worked out of the box as both switch arms were bent so far downward neither spinner would close the switch. Once I properly bent them upwards the right spinner started working but the left, nah. In switch test I removed the plug from the board and shorted the two prongs, which activated the switch so I think I've satisfactorily narrowed it to the microswitch itself. I opened a ticket with PB.
2. The APC drop targets are a bit inconsistent. During reset about once per game one target won't lock in and it makes it impossible to complete the drops since in the down position if you knock down the other two, it will never be able to register a "drop" on the last remaining target. Additionally, if a ball gets stuck on the top of a drop target, when the machine goes into ball search, it never activates the drops so I had to tilt the the machine to break it loose.
3. The two posts at the top of the orbit are inconsistent. I believe they worked on the first couple of games, but even after a few reboots I don't think they are working now. I say this because it seems anytime you are on a mission that requires you to go into the pop bumpers (Derelict, etc), on a successful orbit shot one of the posts should activate to cause the ball to drop through one of the upper rollovers into the pop bumpers. Otherwise you really have no shot at getting to the pops at all. In my case I made several perfect orbit shots during the Derelict mission (and maybe one of the missions that required pops on the "Aliens" rule set?) and they just continued through the orbit back to bumper.
Having noted these small issues, I'll finish by saying that I have around 70 machines in my collection ranging from classics to the newer Godzilla and Rush. This machine is without a doubt immediately my favorite machine in my collection. The playfield flow, sound and light show (GI is a little dark) is beyond anything I've every experienced. The game is just a blast to play. If they fix these other small software issues, this machine will be hard to top.
Yopp
What's the build date on the back of your machine? Mine was 11/2021.
Someone else asked but what code are you running?
I am experiencing a few issues too. My ball when launched gets to the top then rolls back down into the shooter lane. It does this about 30-50% of the time.
My right spinner doesn't seem to be registering or making any sounds when the ball passes through it. I need to check to see what the problem is.
My orbits go into the pops when needed but a lot of times the ball passes through the pops without any action.
I am going through it little by little.
