(Topic ID: 297340)
Pinball Brothers Alien Apron & Lighting Mod
By Red_Devils
1 year ago
  • 1,576 posts
  • 158 Pinsiders participating
  • Latest reply 4 days ago by GamerRick
  • Topic is favorited by 69 Pinsiders
There are 1,576 posts in this topic. You are on page 28 of 32.
#1351 3 months ago
Quoted from JDub03:
Okay I’m feeling stupid at this point. I can’t get the metal to sit flush. There is no space between the trough hood and the bottom of the post. Any tips here would be great. I did loosen the shooter coil assembly. That isn’t the issue.
[quoted image][quoted image]
Mine was super tight and had to really work at it to get it in. Must be frustrating but you’re close!! It is worth it - once it’s in and fired up you’ll be blow away
#1352 3 months ago
Quoted from brado426:
Like I said earlier, loosen your shooter coil bracket. When I was unable to get my apron to sit flush, it was because the shooter coil bracket was too tight and the apron metal piece couldn't slip into it.
I did that right away. The issue I had was all around the ball exit and the post next to it. So I cut the opening a bit wider. Sits perfect now.
#1353 3 months ago
I’m late to the party and would like to order this apron for my Pinball Brothers Alien LV. Since the LV already comes with beacons, do we still need to add the beacons option to the apron? Just want to understand the differences before getting added to the list. I’d also like to include that expansion board as well. Thanks
#1354 3 months ago
Quoted from darkryder:
I have added you to the interested list which can be found on our website at the bottom of the page on the second tab...
https://www.evolutionmodsllc.com/order-status
#1355 3 months ago
Quoted from Red_Devils:
Thank you. Ready to pay deposit anytime
#1356 3 months ago
Quoted from JDub03:
Interesting... I wonder if a change was made in later machines. Can anyone shed some light on this?
#1357 3 months ago
Hey Team!
Just installed my expansion mod for the apron, and once again -- knocked out of the park! WELL worth the extra cash. Thanks again for such awesome work!
#1358 3 months ago
Quoted from Drain-O:
Hey Team!
Are you talking about the Aux Board 10 Expansion? Would you mind taking some pictures from mounting? How is the new multiball lightening like? Such a great mod
#1359 3 months ago
I have a question about wiring up board 8 on my LV. The cheat sheet on the installation instructions says J13 and J21 should have no center pin and shows where they mount. As you can see on my LV, J13 has no center pin but J21 does indeed have a center pin stock from the factory. On my machine J22 has no center pin as you can see in the photo. Anyone know where to go from here?
OR, was my J21 and J22 installed backwards from the factory?
#1360 3 months ago
Quoted from PDX-Mike:
Recently, we've been seeing some machines where the "missing center pin" was at the top for some optos (from the factory). I asked Pinball Brothers about this, and they confirmed that it doesn't matter if it is reversed like your picture. Personally, I've only tested with the missing center pin plugged in at the bottom. I'm guessing it should work both ways, but on my machine, all optos are plugged in consistently (meaning center pin missing at the bottom for all 4 Optos on Playfield Board 8.)
My guess is that it won't make a difference, but I'd say consistency is better.
#1361 3 months ago
Guys, I need a bitt of help trying to track down an Australian buyer, All I have is a company name "Logic Plus Pty LTD" Google tells me the company was sold. On the off chance does anybody know this guy?
TIA
Dave that's me - I was the owner of Logic Plus. I am Jason
#1362 3 months ago
Anyone know where the LV beacons plug in? Trying to non-destructively remove them so I can install the mod-beacons, but they are hard to trace through all of the zip tied wire bundling...
#1363 3 months ago
Also, video included on the install sheet shows connecting Opto 1 & Opto 2 - but not the other two connectors? Where do those plug in?
#1364 3 months ago
Got the LV beacons removed, for reference they plug into the black box in the bottom of the cabinet.
#1365 3 months ago
Quoted from Deadpin:
Only Opto Elevators 1 and 2 should be touched. Follow the cheat sheet on the website. https://www.evolutionmodsllc.com/documentation
#1366 3 months ago
He's 100% correct! These are the changes I will have to make so that the right side fits correctly.
#1367 3 months ago
Same here, I also had to adjust the metal plate to make it fit.
#1368 3 months ago
Quoted from Sjoend:
Can you guys post pics of the machine itself? We'd like to understand what changed about the machine that made it not fit? It fits fine on my early SV machine.
#1369 3 months ago
Same here, had to expand the hole to accomodate a screw on the ball gate....
#1370 3 months ago
I really wish this piece be completely remade with the enlarged areas...and to include the ball guide just above it so that it "bolted" to the playfield. Is this possible?
#1371 3 months ago
Since I still have mine apart in pieces, I'll take some photos this morning and get them posted.
#1372 3 months ago
Quoted from monkfe:
We haven't identified a problem yet. It fits perfectly on my SV without modification, so all I can think is some PB manufacturing change? The only issue I had is that I had to loosen the shooter coil bracket to get it to sit down flush against the playfield. It already bolts to the playfield in 3 places.
#1373 3 months ago
Here are the photos, notice the metal piece is sitting on the scoop hood yet it is not sitting flush against the playfeild. The hole needs to be cut larger at the top to allow it to sit down on the playfeild correctly.
Notice the flap that covers the trough, that screw will not clear.
The photo of the back notice where I marked it with a sharpie. It will not sit flush because the bottom of the scoop hood is clearly in the way where it mounts to the playfeild.
There is no loosening of anything that will fix these issues. I am assuming everyone having issues has an LV model as I do?
#1374 3 months ago
20221213_080625 (resized).jpg20221213_080631 (resized).jpg20221213_080643 (resized).jpg
#1375 3 months ago
Looks a completely different ball trough to me on the LV my Sv is much different. Looks like they went with a model that has the fold down gate when you lift the playfield the balls stay in trough, and that mechanism is what the problem is. yep
#1376 3 months ago
I haven't installed mine yet (LV owner). What will need to be done now as a result?
Appreciate the heads-up on this!
#1377 3 months ago
We're talking about the piece pictured, correct? It's been a while since I installed it, but where is it bolted to the playfield? I recall it being sort of taped to the apron but just sort of sitting there with the one "peg" on the playfield no?
#1378 3 months ago
Quoted from Baggerman:
Yes, that looks like a completely different ball trough than mine. On mine, that metal piece in the picture sits well in-front of the trough bracket.
#1379 3 months ago
I just spoke with our manufacturer, and they say they can create a new design, but they need the dimensions.
How many extra mm here?
And here?
#1380 3 months ago
I will take measurements and photos for you, i'll shoot them to you in an email. Going to measure, then make the cuts on mine to see how it fits.
#1381 3 months ago
OK, all my LV owners out there! I sent the measurements to the OP and here's what I came up with. Please remember I used a dremel, these should fit and I'm hoping OP sends me one to test. This should be the fit for all LV owners.
20221213_172355 (resized).jpg20221213_173520 (resized).jpg20221213_173550 (resized).jpg
#1382 3 months ago
I'm curious how large is this piece that needs modified? I have an LV and my apron shipped a little over a week ago, so I'm wondering if us LV owners are going to get a replacement part or if we'll also need to modify the existing one?
#1383 3 months ago
Quoted from benime:
This is not an LV-specific issue. Plenty of LV owners have installed this mod without an issue. It looks like at some point, PB changed the design of the trough for all. I don't have answers to your questions yet... we just learned about this issue.
#1384 3 months ago
Thanks for doing that. I have sent the measurements to the manufacturers. We'll see what they come back with.
#1385 3 months ago
Firmware update 2.7.37 is now available.
If you have the Xeno Jaw add-on, you will now see a unique strobe effect when in Queen's Nest mode only. During Queen's Nest mode, the jaw partially opens to taunt the player. The simultaneous strobing is just all the more menacing!
A couple other minor fixes are also included in this update.
https://www.evolutionmodsllc.com/software-and-firmware
#1386 3 months ago
I seem to be falling at the first hurdle here... I just can't get the original apron off. I undo the 2 screws but it won't lift off, push forward or budge. Has anyone else had to unscrew or unclip anything elsewhere? It looks like the tabs inside the playfield are holding it on but I can't seem to unhook them as the apron won't push forward?
#1387 3 months ago
Quoted from Ceemunkey:
I beleive you also have to undo the screw by the shooter lane.
#1388 3 months ago
Quoted from Zablon:
Ok thanks I'll have a look for that. The instruction video only mentions the 2 screws at the front.
#1389 3 months ago
It does slide forward... I don't recall any screws on the right, but I haven't done anything with the original apron in a long time.
#1390 3 months ago
Curious for the group with beacons, did you wire all three wires to the beacon controller board? The video said just red & black but I'm not getting anything, so curious if I need to wire the yellow as well?
#1391 3 months ago
Quoted from JDub03:
Red and black only... just like the video says.
#1392 3 months ago
Hello, If anyone is still looking to get this mod - I'm selling my spot for the deposit I paid. Was informed my apron is ready to go. PM me if you're interested, and I'll let Red_Devils know. Thanks!
#1393 3 months ago
Quoted from djsoup:
Hi Red_Devils - ktcoady12 is taking over my spot. Thanks again!
#1394 3 months ago
So... ive managed to get the old apron off but my god it wasn't easy. There weren't any other screws but it was wedged very tight between the playfield and the tabs keeping it in place. I had to lterally bend/pry it off. I also had to Dremel off the metal on the new apron as it wouldn't fit over the shooter lane(as someone else here also had to do).
So now I have 2 issues - one is same as above in that the opto cables that plug into board 8 are not as they appear in the instructions. My opto 2 upper cable has the missing connection on the left, not in the middle. So my question is - do we plug in as normal or do we absolutely have to ensure that the cable at the top of aux board 8 have the missing connectors in the middle?
Second issue is the software - I have installed .net core 3.1 but the Annunciator sofware still won't install and says the .net core is required...?
#1395 3 months ago
On the software side (assuming you are running Windows) you need the desktop agent of 3.1, make sure you're installing the correct x64 or x86 version for your computer. I did the first link the first time and it's not correct. Read the page. As for the second question, I will defer to the guys who made the board for support, reach out to them on their site or they will reply to you here. They have been fantastic supporting this mod.
#1396 3 months ago
Hi!
Glad you were able to finally get the original apron off. I recall struggling with mine a bit also.
The instructions say to ensure that the top connectors have the missing pin on the left. Not in the middle. We have seen some machines recently that had the top with the center pin missing and bottom with left pin missing, so we suspect that it doesn't matter. However, we have only personally tested as it is written in the instructions. I have confirmed with PB that without the apron mod, it doesn't matter if the top and the bottom connector are reversed and occasionally, you'll see one reversed from the factory.
As for the .NET Core framework, you need to install this one for 64 bit:
https://dotnet.microsoft.com/en-us/download/dotnet/thank-you/runtime-desktop-3.1.32-windows-x64-installer
or this one for 32 bit:
https://dotnet.microsoft.com/en-us/download/dotnet/thank-you/runtime-desktop-3.1.32-windows-x86-installer
At some point, I will update the tool to use .NET 7.
#1397 3 months ago
Mine was the same and I suspect it's because of the trough redesign. Once you remove the three screws (two on front hangers and one on the shooter lane post), there's no room to slide it forward due to the trough mech hanging it up. I suspect new installations will require folks to drop the trough mech in order to slide the apron; I also used a pry bar for removing tack strips to gently bend the original apron enough to get it over the metal ball guides and then I could lift the apron directly up.
#1398 3 months ago
Just chiming in…new apron…same fit issue as other above. The piece in question is just on with double sided tape so hope to dremmel out the needed space.
#1399 3 months ago
I'm really not having much luck with this... I got the software installed and updated the firmware on the apron, but after connecting all cables, there's no power to it - no lights come on and when the machine starts up the mother switch keeps kicking (I guess it thinks there is a ball in there). I double checked all the cables were correct and they are... ive disconnected everything for now and I'll reconnect the original optos etc but this is proving to be a little troublesome. I guess I'll have to raise this through the website too.
#1400 3 months ago
PM'd you.
$ 19.95
Toys/Add-ons
$ 9.95
Mitchell Lighting
Led
Other
$ 99.95
Hookedonpinball.com
Shooter rods
Other
$ 8,595.00
Classic Game Rooms
$ 165.00
Evolution Mods
Interactive
Precision Pinball prod.
Flipper parts
$ 299.95
Pin Stadium Pinball Mods
Led
Flipper parts
This page was printed from https://pinside.com/pinball/forum/topic/pinball-brothers-alien-apron-amp-lighting-mod/page/28 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
