(Topic ID: 236558)
Pinball 2000
By schradermt
1 year ago
  • 21 posts
  • 10 Pinsiders participating
  • Latest reply 1 year ago by wayout440
  • Topic is favorited by 9 Pinsiders
#1 1 year ago
Anyone successful building a computer that will run the pinball 2000 software or nucore.
#2 1 year ago
Yes, many. I'm actually about to resurrect one that I started and attempt to complete it. All I can tell you is the computer I am using is an HP Compaq AMD 64. It ran, but the onboard sound was not working correctly, mostly noises. I installed a SoundBlaster card and reinstalled the software from the ground up and then the sound worked. I intend to use the existing CRT so I have a video converter card on order to try out.
#3 1 year ago
I'm really interested in doing this in the future. Getting ready to pick this machine up and looking for a backup plan in case the computer craps in the future. Not really sure where to start. Do you have to find an older computer? Software?
#4 1 year ago
Yeah, a little older - but not ancient. Dell small form factors like the Optiplex line seem to work. Being a horizontal case they can be fit into the mounting location better than a upright desktop. You also need a parallel port to run to the driver board. I can't guarantee anything - as I am just experimenting right now. The software is out there: both Pinbox bootleg and NuCore which has been made available for download. You'll also need an external audio amplifier if converting from the original hardware to a PC.
Oh, and I will be also using a solid state drive so that I can nudge!
#5 1 year ago
Ok. Far down the rabbit hole now. The actual computer I am using is an HP Compaq dc5750 Small Form Factor. I was going to use a PC to Arcade board to keep the original CRT, but it didn't work very well, and the monitor started going wonky went I went to backtrack. So now I am going with an LCD monitor, that's on order. Gutted the head and figuring out where to put things. I just received my audio amplifier yesterday and it works nicely.
#6 1 year ago
Wayout440 would you build me a couple? I have the dell pc that bos told me to get. I would gladly pay you for your time. Dave is just so busy at the moment. Let me know! He had me buy the dell pc’s and the sata drives.
#7 1 year ago
I have 2 brand new and original sheets of glass for pinball 2000 machines if anyone is interested . I also have a wide body Invisi glass sheet brand new..
Let me know please ...
#8 1 year ago
I have a couple of spare computers that I built for a client that fell off the face of the Earth. Email me directly if you can't find someone to built you one, and would like one.
Rob Anthony
Pinball Classics
http://LockWhenLit.com
Quality Board Work - In Home Service
borygard at gmail dot com
#9 1 year ago
Mounted PC and LED strip lamp. Just need the monitor to arrive.
#10 1 year ago
so do the prizm cards still get used in the computer?
#11 1 year ago
Quoted from schradermt:
No.
#12 1 year ago
I have a computer that I’m sending to rob at pinball classics to repair. I sure would like to build an after market system though. The dell computer your using what are the specs so I can find one.
#13 1 year ago
Can you use any of the micro form factor Dell PC’s like the Optiplex 5050’s or 7050’s?
#14 1 year ago
Happy Hour! Back up and running with new PC, Pinbox, sound system, and 22" widescreen LCD!
#15 1 year ago
Quoted from Pbpins:
Probably, but can't be certain. Somewhere I read that AMDs were not recommended, but I used one anyways because that is what I had on hand. It is an HP Compaq dc5750 Athlon 64 X2 2.0 GHz. Works great, but like I said, I had to install an aftermarket Soundblaster card because the onboard sound was garbled. You might find the onboard sound on a Dell to work, but there are so many models so no guarantees.
#16 1 year ago
Nice have fun!!
#17 1 year ago
I know people have said in the past that a Raspberry PI wouldn't work for P2K. Why not? Seems like they are powerful enough. Is it a connection thing?
#18 1 year ago
Quoted from Zimmer:
You need a parallel port on the pc to connect to the playfield driver board.
#19 1 year ago
Quoted from cabuford:
There appear to be parrallel to usb devices. Is this the only reason no one has built a disk image?
#20 1 year ago
Quoted from wayout440:
Can you share further details on the monitor and how got this all going on a PC?
Thanks.
#21 1 year ago
Quoted from GCS2000:
Thanks.
The monitor I chose is a Dell P2214H IPS 22". I temporarily set it up from inside the back of the back box, where the original monitor sat, but since it does not fit into the cutout for the original monitor, I was not happy with how the image was lining up and sitting too far back. I had to have the monitor mounted on the other side of the cutout above the glass to put the image in a better position. My mounting is all DIY.
Getting the game on a PC isn't super complicated. It's a Linux based iso. The only problem is it won't run "out of the box" until some code/configuration lines are modified.
$ 279.95
Pin Stadium Pinball LEDs
$ 63.50
€ 159.00
FlipperLED
PinWoofer
