As an easy fix you can color the second line (lower half) completely in white with the rectangle tool. You can also to assign a different detection mask which recognizes the difference and have 3 different ColMasks
It was because I had the numbers colored differently than the words so they "popped" better, but the trigger used the "shoot for" as a trigger.
I think I can get it sorted. We need to get video mode working better!
Quoted from Malenko:We need to get video mode working better!
I know ! Still waiting for steve45 for the editor implementation.
Quoted from lucky1:As an easy fix you can color the second line (lower half) completely in white with the rectangle tool. You can also to assign a different detection mask which recognizes the difference and have 3 different ColMasks
Thanks Lucky1! I modded the Colour Mask as you suggested. It's not as cool as Malenko's original Mask but it works for now until he has the time to make the frames as you suggested (that really is beyond me - I've tried), here are the files:
BETA WIP T2 FOR REAL PINBALL MACHINES https://1drv.ms/f/s!Ao6k3CIlgOqjorIANKZ0E-Dk5WLb1g
Ready to install into the SD card and tested as working on a real machine with L8 and Pf2 roms
I think thats fixed and added more stuff, new DL link: https://drive.google.com/open?id=1Logz-tz-1Y_7M5S1M37oGH1x-_kerrbb
I finally managed to upgrade to Version 1.40 on my T2 real pin.
Looks pretty good, most issues are solved, thank you!
I just find a few little things...e.g. color issues during gameplay when you get the Hold Bonus or when it's showing the replay score.
If you still work on bugfixing I can make some gameplay videos.
Just send me a message.
Stefan
Hi.
I have detected the following errors:
. Four-player punctuation game is not good color, but works well with one, two and three players.
. Autofire and similar animations are painted in yellow part of the screen instead of the light beam of the shot.
. Repaly at looks two colors (red / yellow).
. The ball number is white when it should be in red.
Please tell me how to fix it or if someone has the files correctly working. The files fsq and pal are downloaded from the thread link.
Thank you
Quoted from aarguez:Hi.
Thank you
I'll update the mask for 4 players. theres an erroneous red box there on my latest build.
Are you on the latest firmware (2.66)? I havent had an issue with that
I am going to redo the match game, just havent had time
the ball number is supposed to be white.
Is anyone still looking into this or is this a dead end?
Did anything about the way colorizations are done change so we can finish the video mode?
I put together an update, its much more complete (and complex) but it still has a few small bugs and video mode is still undone.
https://drive.google.com/drive/folders/1Logz-tz-1Y_7M5S1M37oGH1x-_kerrbb
From the Readme:
Terminator 2: Judgment Day Pin2DMD Redeux Readme
Re-Colorization of Terminator 2.
Feel free to alter my work however you want. I would prefer you release the source files for any changes but I can’t make you.
Big thanks to WOB for finding time to do some rips/dumps for me.
Im restoring a real T2 pin, so I want to get these files as perfect as possible!
This going to re-use some colorization from the second release I ever did, but most of the triggering will be redone in a better method.
Post any bugs in the TDB thread:
hxxp://to.be.determined
To be done
Williams squared in logo
check dropped frames on match game
check dropped frames on game over
Some HK explosions
Video mode??!?!
1.70 The "I have spent more time on the redo than I did on the original" release
Changed to a newer build. I think some issues were from the old build, like "special thanks"
New "Go","Run", "Lets Go" , and "Shoot For Video Mode" palette triggers
yet more "special thanks" triggers. I dont understand why its not triggering at this point if its not a bug.
New "Big Arnie" sequence, where he fires the big gun. Its 2 frames, so I redid both and framed 1 to 1
Retriggered "chase loop" , 3 sections like before, same colors, new triggers/masks
Credits/FreePlay with Push start under, redone again. if it's still screwy I'll untrigger it and leave it with default colors.
Logo transition to "starring arnie" added a lot of transition triggers. No, way more than that. Yeah, about that many.
Extra Ball Is Lit, given its own frame and triggers (alignment issue with outlane mask)
Load the Gun to SuperJackpot retriggered
50,000,000 New mask, trigger, and color
New 50,000,000/Super Jackpot sequence with 1 to 1 triggering
Replaced Video mode announce and instruction screen
Put Video mode in Red as a place holder
VideoMode Win screen cut and triggered (dynamic)
1.60 21 more hours release
Fixed palette bug in "kickback lit" / Autofire
Extended color timing of "Williams Logo"
Added more "big Arnie" triggers
Hopefully fixed the flashing credit counter on "Push Start"
Added *another* special thanks trigger
Match Game- changed timing to hopefully fix the blinking text. Its irritating me
New Multiball Mask, its prettier Multiball in red with a gradient grey background and random dithering
Lock the Ball trigger to load the gun (ROM difference?!?!?)
New trigger for Extraball. Has same hash but triggered on WOB recording
Added Return Lanes Lit, something else I dont think my game has, or I suck and WOB is that much better
Finished triggering the 30+ frames of the HK / reticle for the skill shot
New palette for T2 intro logo and judgment clasp.
-added red drop shadow to judgment day
Adjusted Ball/Credit Mask (there was blue bleed)
New database mask and triggers (better contrast)
Jackpot Value display, new mask new colors new triggers
Jackpot Multiplied
2X Multiplier 1 to 1 framed and colored
4X Multiplier 1 to 1 framed and colored
6X Multiplier 1 to 1 framed and colored
8X Multiplier 1 to 1 framed and colored
"Extra Ball Is Lit" uses same mask as "return lanes are lit" but with its own triggers
"Hurry Up Is Lit" uses same mask as "return lanes are lit" but with its own triggers
Hurry Up count down, new mask and trigger
New triggers and frames for "Shoot" , "Again", and the T1000 opening the elevator doors
3rd ball Highest Score: new mask, new triggers , new colors
Load the gun, new trigger on WOB recording
Corrected "Shoot For" mask and triggers, should work for 1x,2x,etc Jackpot
Added exploding HK frames, tail section.
1.50 The old colorization source code doesnt seem to be working in the new editor, hence the re-write
Long term goal is to retrigger EVERYTHING using WOB dumps.
Match Game
-all old triggers, frames, and masks are deleted
-New frames, triggers and masks for the reveal of the press, match word and numbers
-Separated into "Intro" "Match Word" "Crush Words" and "Crush Numbers"
-Crush numbers triggers the same frame masks and the words, triggered on the trailing zero
-each frame has a zero value, so it should stay until replaced. That should correct artifacting on numbers.
T2 big frames
- 1 to 1 matched
-Title and Judgment Day plates slide in 1 to 1 matched
-"glisten" frames triggered 1 to 1
-wipe to arnie masked and triggered 1 to 1
-Arnie wipe to last score (still not perfect but not much else I can do)
Special Thanks
-redone and retriggered, with extra triggers
Grand Champion/Top Marksman
-redone with replaced triggers (and more of them)
Williams logo
-redone, all new triggers (over 400!)
-All 3 transitions done
-Handwriting
-appear in square sections
-box wipe from the left
Door opening
Same colorization frames, new triggers (checkpoint 1 secure,etc)
After Ball Bonus:
New mask, new triggers
Chase Loop:
New triggers for old scene
-Old scene looks kinda weak, but I spent way too many hours on it to delete
New Mask and trigger for Chase Loop Value
Pull Trigger to shootball
1 to 2 framing done (1 frame to 2 triggers)
used old color frames as a base, but fixed some color oddities
Payback Mode
New color mask, new triggers
Highest Score
Credits (coins)
Created new mask that works with most (all?) credits in machine along with push start
Shotgun Arnie
-Same mask, new triggers!
T1000 face
Cyborg Tissue
-Completely redone, masks and triggers
Highest Score
-redone with masks and triggers
T800 with lightning strike
-retriggered, same old animation
"Big Arnie"
-new triggers
Thanks to WOB for beta testing this.
I never touched Stargate, but hey get the files enjoy the games and send me money later if you want. The important thing is to have the games in color
This page was printed from https://pinside.com/pinball/forum/topic/pin2dmd-colorization-of-terminator-2/page/3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
