Can anyone provide me pictures of the LED backbox insert they have installed? I'm building one for my Ironman currently and could use some inspiration on LED placement. I haven't found a layout that really pops in my mind yet.
Wanna build 2 while your at it? Ask this guy for some pics.
https://pinside.com/pinball/forum/topic/fs-huo-imve-4700-york
I'm planning on building a few. I can't justify spending 200 bucks for a piece of cardboard with LEDs glued to it. Once I figure out a layout, it shouldn't take me long to pump out a few.
I posted a couple of treads on how to do this and used Tron and IM as examples: https://pinside.com/pinball/forum/topic/how-to-make-flashers-or-under-cabinet-lighting-for-15-for-modern-sterns
There are some pictures if IM in there. Happy to take more photos if you need them.
This thread is on making the backbox LED panel: https://pinside.com/pinball/forum/topic/how-to-make-an-led-backbox-for-30-for-modern-sterns
I just glued 4 rows of RGB LEDS and have them on a fade pattern and it looks pretty sweet, but it's almost too much. I realized that you need to actually make a pattern to highlight certain pieces of the art. I took like 2 hours to put it together including soldering the strips together.
Quoted from Grinder901:I want one of these so bad
You mean to tell me the Grinder has every mod but this?!? How can this be so
Quoted from ff6735:You mean to tell me the Grinder has every mod but this?!? How can this be so
Haha! Hey, I'm working on it!
Quoted from Deez:I'm planning on building a few. I can't justify spending 200 bucks for a piece of cardboard with LEDs glued to it. Once I figure out a layout, it shouldn't take me long to pump out a few.
I'll buy one.
You guys remember when an interactive backbox was just standard in a pinball machine??? I'm a Stern lover, but it drives me nut that they did away with that.
I had one of these in xmle and ripped it out, but the one lyonsden made is awesome. The flasher hook up and positioning is awesome!
And the pulsing arc reactor! too cool... and this coming from a guy who normally doesn't dig on this type of mod.
I'm looking into a more efficient way to build the connectors. I'd like to design a small board that piggybacks on the existing flasher headers. I'm thinking it could have a board with connectors similar to the 40-pin connector on a system 6 game and then a set of header pins for the existing flashers to plug into so it would be a cleaner install.
Quoted from Deez:I'm looking into a more efficient way to build the connectors. I'd like to design a small board that piggybacks on the existing flasher headers. I'm thinking it could have a board with connectors similar to the 40-pin connector on a system 6 game and then a set of header pins for the existing flashers to plug into so it would be a cleaner install.
Yeah. The harness is a killer when making these. This is what I've come up with as a partial solution. A protoboard that acts as a splitter. One set of plugs is coming from the flashers, then I can split to backbox, cab, under backbox, Arduino, etc.
image.jpg image-353.jpgWanna join the discussion? Please sign in to reply to this topic.
This page was printed from https://pinside.com/pinball/forum/topic/pictures-of-iron-man-led-backbox-insert-needed and we tried optimising it for printing. Some page elements may have been deliberately hidden.
