(Topic ID: 177797)
pictures bonus system super soccer/300
By wizardblom
2 years ago
  • 9 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by TimMe
#1 2 years ago
Need pictures of the switch counting the bonusballs and set switch for next ball. The one I am having now uses a coin switch, but that one is broken. Can't imagine Gottlieb using these type of switches, almost a mission impossible to get it working the right way...think it is a make/brake system with two contacts.
#2 2 years ago
If you are talking about the switch stack at the end of the bonus ball rack, here they are. Note that Super Soccer and 300 used different switch assemblies.
- TimMe
#3 2 years ago
Thanks, couldn't figure it out with the coin switch, balls got stuck and the switch did not look original. Let's see if I can order/get one.
#4 2 years ago
Don't know if there is a sub assembly on the rail itself or if the plastic pin is sticking throught the hole in the rail.
So..if anyone has pictures of rail itself I would be grateful, it is the last mountain I have to climb before it is playable.
Only thing after that... adjusting the score reels, always the habit of getting stuck on 9 to 0...
#5 2 years ago
There is supposed to be a long, U-shaped wireform in the track that pushes down on the switch. When one or more balls are at the gate on the far left side of the track, they push down on the wireform, which actuates the switch. There's a pic on IPDB where you can see the wireform fairly well through the backglass:
http://ipdb.org/showpic.pl?id=2539&picno=48610&zoom=1
- TimMe
#6 2 years ago
Here you go! Found these pics I had on file following a 'Top Score" resto many years ago.
#7 2 years ago
I need the whole assembly, somebody has one?
Can't get it to work with a micro switch, the contact arm is to long and heavy giving to much bonus points and sometimes not switching back for the outhole to work...
#8 2 years ago
Thanks to hoov I will have the assembly in a couple of weeks!
Another machine rescued
#9 2 years ago
That's what we like to hear!
$ 399.95
Third Coast Pinball
$ 1.95
Various Novelties
Pinball Wheezer
$ 29.99
$ 107.95
Hookedonpinball.com
$ 29.99
$ 199.99
$ 40.00
$ 495.00
MI Pinball Refinery
$ 24.95
The MOD Couple
$ 64.99
Medisinyl Mods
$ 48.00
$ 800.00
Playfields
Pinball Playfields
$ 495.00
MI Pinball Refinery
$ 9,000.00
