At first glance I was not sure what I got my self into. However I have wanted an embryon so I took a gamble and brought this home today.
After looking it over for a while I noted the positives:
Found 11 cents inside.
Its all working and playable with a drop target bank switch issue.
All the fuses are the correct value. Thats a first for me!
The bottom side of the playfied is really clean! I was actually shocked how nice the underside looked after seeing the top side.
The playfield mylar was found safely stored rolled up inside the lower cabinet so it is still mint NOS!
It came with the manual. I count that as a plus.
The bad so far seems like typical things for a machine that looks to have been left untouched for many years.
Rubbers are all fossilized and most actually just break apart so they are easy to remove.
Needs a new plastic set. Most are still good some are bad may as well go with a new set.
Pop caps all went straight in the trash.
Anyone have any idea what the 2 wood blocks were for? I assume they were shipping blocks of some kind
Some bookkeeping info written in the manual from 1982
