(Topic ID: 17380)
Picked up a Rollergames, question on upper flipper
By Dewey68
7 years ago
  • 9 posts
  • 6 Pinsiders participating
  • Latest reply 7 years ago by Dewey68
#1 7 years ago
I picked up a Rollergames this week. Cleaned it up and put new rubber on, leveled, etc. Slope is at 6.5 degrees. I don't have experience with this game, so those that do hopefully can answer this question. At 6.5 degrees of slope, should the upper flipper be able to make the wall shot every time it's held by the magnet? I'm probably successful 40% of the time when held, but can hit it many times when it's not held and just "passing through". Wondering if I need to look over the flipper or this is normal.
#2 7 years ago
IMO it's not a guaranteed shot under any circumstances, although if you get the timing just right it should be pretty predictable when the magnet holds the ball.
#3 7 years ago
I've always been curious about that too. The only one I've ever played the magnet never helped at all.
#4 7 years ago
With the magnet activated that should be a 100% shot all the time. The problem I had with mine at one time was the magnet post had a groove worn into it. I took it out and smoothed off the groove. Readjusted to the proper height and I was making that shot once again everytime. Rebuilding the upper flipper might be needed too as that flipper coil strength isnt' the strongest since it is such a close shot. Just throwin ideas out there.
#5 7 years ago
When I had my RG the left ramp was also 100% with the magnet energized.
#6 7 years ago
Quoted from beauimpala:
I took it out and smoothed off the groove. Readjusted to the proper height and I was making that shot once again everytime.</blockqu
There is a little wear around the magnet so maybe it's sitting too low. The flipper seems to have decent power as I can make the wall shot if timed right going through the loop.
Thanks for the pointers guys, I figured it should be almost a sure thing when held by the magnet.
#7 7 years ago
If i remember right that magnet post is threaded. Just adjust the height a tiny bit for starters to see if that helps.
#8 7 years ago
The magnet shot should make the wall every time.
#9 7 years ago
Looking at the base of the ramp both holes where the screws hold it down are broken, so I'm thinking that is the problem.
Bay Area
$ 99.00
Pinball Sales
Yorktown Parts and Equip
Gweem's Mods
2,000 (OBO)
Williamsburg, KY
2,700
Sale Pending!
Sebring, FL
Music City Pinball
$ 154.00
Id Rather Play Pinball
Third Coast Pinball
