I cannot find one on line anywhere and want to do he ground mod as I am having wierd issues. Also need to see where to ook up ground mod on Ni_Wumf Driver. Thanks guys!
A little more information would be helpful, like the name of the game and the problem you are having. I'm guessing it is a Gottlieb?
Rottendog made a sys1 replacement?
The idea behind the system1 ground mods to run common ground wire all to that grounding panel in the cab. So just find a good spot on the MPU's ground plane you can easily solder a wire to run to the ground plane. Be neat when doing this. You can make the ground mods look really hackish if you are sloppy.
This page was printed from https://pinside.com/pinball/forum/topic/pic-of-ground-mod-on-rottendog-ps-and-cpu-anyone and we tried optimising it for printing. Some page elements may have been deliberately hidden.
